We have a RCA tv that will not turn off using the power button.
RCD tv no longer responds to remote control and any button pushed on the tv (except the power button) will power on or off tv. Power button does nothing. If volume needs to be adjusted, we have to push any button and hold until desired volume level, because once button is released tv powers off. Push any button again and tv powers on, with correct volume. If anyone can provide any insight to this problem, it would be much appreciated. The is a 32" RCA tv model # 27F630T and is about 4 years old. Thank you.
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Hi! You can try using these steps for you to program your RCA remote control to your LG TV.
1. Manually turn ON your TV. 2. Press and "HOLD" CODE SEARCH 3. Press and release the TV button 4. Release CODE SEARCH. 5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second). 6. Once the TV turns off, press and release ENTER. 7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
This remote was also supplied by RCA for their VHS player, model # VR629HF.
The instructions to program it can be found in the user manual for the VHS player: http://www.retrevo.com/support/RCA-VR629HF-VCRs-manual/id/19241ag112/t/2/
1-Turn on the TV
2-Find the brand and code number(s) on the code list on the next page
3-Press and hold the TV button on the remote.
4-Enter the code from the code list.
5-Release TV, and then press CHAN up or down. If the TV responds to the remote commands,the remote is programmed.
6-If the TV does not respond, repeat these steps using the next code in the list.
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
My friend you gotta turn on manually your tv first.Then push and hold until the indicator light lights,then release the code search button now push and release the Tv button after that you gotta push and release the power button until the Tv turns off then you push the enter button to save the code.Good luck.
Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
Once the device turns off, press and release ENTER.
With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
If the TV is in "parental lock", then it will not respond to the buttons on the front of the TV. Get a cheap universal remote control, program it for RCA, turn the set on and go through the menu to unlock.
