Question about Canon MV730i Mini DV Digital Camcorder
Camera records no video
Hi, Without logical reason my mv730i stopped recording video. When I switch on the camera the canon display's appears, the menu options are working. When I swithc to "camera" mode the display is black, but the counter, batt capacity ect. are being displayed. Audio is recorded correctly, but no video. The camera is to big to become a memo recorder so I would like to record video again. Is the anybody that had the same problem, and how did you fix it? with regards, John
  • Anonymous Dec 12, 2007
    i have exactly the same problem, i can play back video ok, but cant record anything, can you suggest a soluition ??
    thanks
    GW
Hi John, my 730i is driving me mad too http://www.dpreview.com/news/0510/05100602canon_ccdproblem.asp this might help us both. Steve
Posted on May 12, 2007
The led screen is not working all the index comes up but when you record the screen is blank it records the sounds but no picture its the same through the view finder canon mv730i
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 13, 2011 | Canon MV730i Mini DV Digital Camcorder
Canon MV730i video camera records sound only, no picture. No picture on playback either.
did you recording on differant taps, does all of the dont give you picture.
try clean the head with a head cleaner and then try.
Sep 24, 2008 | Cameras
Can't transfer data from the cassette to the 1GB memory card?
Remember 1 gb mem card is not big, I have a Sony camera and just 4 min on my digital tape recording with sound is 1.6 gb okay, just buy a bigger card and you will be fine.
May 23, 2010 | Canon MV730i Mini DV Digital Camcorder
How do i make this product 16:9? it seems to not let me.
See Page 39 of the Online Manual - link below
Goto Camera Menu> Camera Setup > 16:9 > On/Off Make sure you are in camera Mode - see page 46 - modes 16:9 can be used in See also page 77, for details of how 16:9 can be set and used - see below
  • The 16:9 mode is an electronically processed effect.
  • The 16:9 mode cannot be selected in the Easy Recording mode.
  • The multi-image screen cannot be used when the 16:9 format is selected.
  • Simultaneous recording on a memory card cannot be used when the 16:9 format is selected.
  • If you play back a 16:9 recording on a normal TV, the image appears vertically “squashed” (compressed).
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 06, 2010 | Canon MV730i Mini DV Digital Camcorder
About transfering video from the tape into PC
Hi, You do need a firewire cable (which is normally provided with the camera) and a firewire port in your computer in order to get images off the tape which you have recorded onto.  The card however can be accessed via USB.  The card can store video as well as pictures although if it is the card that you bought the camera with it probably has very low memory. If I were you I would take one of these two solutions
  • Buy a firewire cable and a firewire PSI card for your computer.  Use an editing software eg. Pinnacle or Windows movie maker to import video files from camera.
  • On the camera above the power switch (camera, OFF, play), there will be a switch which at present is down indicating to video.  Switch it up to card.  This will then record video to your card which you can load to your computer same as the pictures.  You might need to buy a new SD card (located in compartment -Multi Media Card- next to lcd screen.) these can be quite cheap and 1 GB can hold more than an hour of footage.
Hope this helps- Any more questions just ask
Jul 10, 2008 | Canon MV730i Mini DV Digital Camcorder
Sd elite pro 2gb
What is the error message you are getting?
Have you formatted the memory card?
Jun 09, 2008 | Canon MV730i Mini DV Digital Camcorder
Can't turn on my camera!
Hi..
I have a link and some information I found on the video option to your camera. This link is for the manual located on hp.com:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=371583&lang=en&cc=us&lc=en&dlc=en&
The following is how to stop video:
To stop recording video, press and release the Video
button again; otherwise, the video will continue recording
until the camera runs out of memory.
NOTE
If you have set the camera to Self-Timer or Self-Timer -
2 Shots (see Using the Self-Timer Settings on page 44),
the camera will start recording 10 seconds after you press
the Video button. However, with the Self-Timer - 2 Shots
setting, the camera only records one video clip.
After recording has stopped, the first frame of the video clip
appears on the Image Display. While it is processing, you can
delete the video clip by pressing the Menu/OK button
Good luck and please let me know if there is anything else i can hep you with--feedback would be geat.. thanks, d
Feb 27, 2008 | HP Photosmart R707 Digital Camera
Mv730i issue
Since neither the specs nor the website mention widescsreen recording, I think it's a safe bet that it just shoots in 4:3.
Nov 30, 2007 | Canon MV730i Mini DV Digital Camcorder
Camera stops shooting by itself
if its sound is beeping, it means the mechanism have an error. Check the small fuse of the power supply
Jun 03, 2007 | Canon ZR200 Mini DV Digital Camcorder
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Canon MV730i Mini DV Digital Camcorder Logo
252 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
