Question about Western Digital Caviar 500GB Internal SATA Hard Drive
Cannot see External USB Drive WDC 500 GB
Drive seen in Device Manager (Drives and USB Mass Media) working properly. Do NOT see it in Computer Mngt / Drive Mngt or using Data Lifeguard.
Used on a Dell600 XSP - all system OK
Can you help?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
  • 558 Answers
You may need to initialize it.Right click my computer select manage when it opens on the left side look for disk management click on it.It will open on the right.IFyou see the external drive right click it choose initialize. Once this is done you should see it under my conputer.
GOOD LUCK
Posted on Aug 31, 2009
My 750GB external mass storage device cannot be detected by my computer, and it produces sound
from what you describe it sounds like the drive itself has given up, return it as faulty. your data may be lost.
Apr 02, 2011 | Hitachi 500 GB USB 3.0 Portable External...
My notebook is not detecting this desktop drive (3.5'' 1 TB external desktop hard drive - verbatim). My other 500 GB external hard drives are properly detected.
Go to Control Panel - Administrative Tools - Computer Management Then go into Disk Management. Hopefully you will see a drive with a capacity of about 480 GB (plus or minus), that's your disk.
Right click on it and select change drive letter and change the drive letter to something that isn't in use.
If that doesn't work or it doesn't show up, go into the Device Manager from the Computer Management screen and see if there is anything under disk drives with a yellow or red symbol next to it. If so, right click it, select uninstall, then unplug the disk drive and plug it back in.
Feb 27, 2011 | Verbatim 1TB SMARTDISK HD USB-FWIRE COMBO...
External Sata Drive no longer recognized
My friend it sounds like your hard drive. I know thats not what you want to hear. But don't worry there is hope! You can have the data retrieved from your hard drive by using this online company which I highly recommend:
http://www.gillware.com/
Aug 10, 2009 | Western Digital My Book Home Edition 500...
Not recognized
This may not be the external hard drive issue. Check your USB driver, under device manager. You might need to upgrade the driver. If you plug your external to another computer, you will see that is it working ok. Just re-installing XP might have not installed USB drive properly.
Jun 19, 2009 | Fantom Drives G-Force (GF500EU) 500 GB USB...
No drive letter
When remove the drive do this steps properly first when you want remove the drive remove safley than remive it
Jul 13, 2008 | Western Digital My Book Essential Edition...
HD PROBLEM
Have the same problem with
TOSHIBA MK1234GAX USB Device
Did You solved it?
Jun 13, 2008 | Computers & Internet
Can't get it to work
What operating system are you running? Windows Me or older has troubles finding plug and play external hard drives sometimes. If so look up some how to's on google for installing your model of external hard drive on to the operating system you're using. Although if you're using XP or Vista you may have an issue in your Device Manager. In that case you will need further instructions.
Jan 22, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
COMPUTER COULD NOT DETECT WDC WDG1U5000N WHEN INSTALLED
Had the same problem...tried everything with no results. In desperation, I grabbed a different USB cord, plugged it into the drive and the laptop and VIOLA! my laptop could see it again! Maybe this will help someone. Cheers!
Dec 15, 2007 | Western Digital My Book Essential Edition...
Western Digital MY BOOK 500gig - Drive does not appear
If it is showing up in your device manager - is it also showing up in the disk manager? If it is you can check if it has a letter name attached or if you need to give it one.
Oct 02, 2007 | Western Digital My Book Essential Edition...
Western Digital Caviar 500GB Internal SATA Hard Drive Logo
235 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
