Question about Tecnik TKC8522 Electric Double Oven
TKC 8522/2 top oven outer door shattering
My oven was not on, no-one was near it and it hadnot been damaged in anyway yet without warning there was a crack noise and the outer glass of the top oven shattered. It did not fall out and is still in place but shattered like a car windscreen. Could this be because of a fault when tempering the glass and can you confirm that the glass for this oven is tempered glass.
Are you aware of this happening before with this oven. The oven is 3 years old and as pensioners with just the 2 of us in the house we are very careful with our belongings.
  • jerryaike138
    jerryaike138 Feb 10, 2012
    We just experienced the same issue. Oven was not in operation and the top glass cracked and fell out. Miele's comment is that it is not their problem. They will be glad to fix at my expense. Amazing! They told me they did not have a problem - guess I will have to get an attorney to get their attention!
  • 41 Answers
The glass would only shatter if it was installed backwards but then it would of shattered a long time ago it shattered due to a scratch on the glass or the door was damaged
Posted on Jan 01, 2009
  • Tecnik Master
  • 3,463 Answers
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Posted on Dec 31, 2008
Worn lettering on Technik oven TKC 8522 and 8525.
You can buy new decals for this model from Ovenlettering.
Mar 23, 2014 | Tecnik Ovens
Oven door glass shattered
Replacement is likely not to be easy or cheap, but necessary.
Jan 10, 2014 | Tecnik Ovens
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Sep 25, 2010 | Tecnik TKC8522 Electric Double Oven
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Main oven door outer glass panel shattered
I doubt you will get it cheaper any where, Zanussi is a bit of a closed shop.
If you can let me have the exact model no and the er number, I might be able to help you.
As for the reason it shattered, there are numerous reasons for this to happen, too many to go into, but it is a very common problem with cookers..
They do just go without any warning.
A cold kitchen could indeed be a factor, a badly fitting door is another factor, i could go on and on and on!!!!!
There is no one thing it can be put down to.
Plz let let me have the details I ask, and I will see what I can come up with.
Dec 12, 2008 | Ovens
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Tecnik TKC 8522 or 8525
hi if you contact tecnic should be in the manual they should be able to supply you with a new facia for the cooker good luck.
Mar 06, 2008 | Tecnik TKC8522 Electric Double Oven
Tecnik tkc 8522-8525
You need something thin and strong to slide underneath the screw head. Then turn slowly while lifting the screw head. The thread should catch and the screw should back out.
Mar 02, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Tecnik TKC8522 Electric Double Oven Logo
776 people viewed this question
Top Tecnik Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
