Question about Motorola Mobility Logitech Mobile Bluetooth Over the Ear Headset for RAZR V3c Verizon Cell Phone (980228) Headset
I bought a pink motorola bluetooth headset but can't get it to be recognised on my raz phone.
No instructons came with the headpiece and when I tried to setany bluetooth item.The phone doesn't find any bluetooth item when I try to set it up. Have you got any detailed instructions please.
SOURCE: headset stopped connecting
ya it happened to me once the pick up button and hold for 4-5 seconds till the blue light lights up then unfold it and then search
Posted on Nov 13, 2007
  • 2351 Answers
SOURCE: maual for Motorola H350 bluetooth headset
This may help. Click the link:
Ignore the chinese as you go. Its like mixed together but you'll find what you need. Good day!
Please vote.......
Posted on Jan 17, 2008
SOURCE: Motorola Bluetooth® Headset H555
go to bluetooth on your phone and press''LOOK FOR DEVICE" but turn your bluetooth on
Posted on Feb 18, 2008
SOURCE: Motorola Bluetooth HS850 Pairing Mode
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
Posted on May 18, 2008
SOURCE: Bluetooth Motorola Headset H500 (Pink)
I'm sure it's "0000"
Posted on Aug 30, 2008
  • 827 Answers
SOURCE: Sony Ericsson not recognising motorola n356 headset re bluetooth.
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
0 characters
1 Points
Have a cell phone that is Bluetooth compatible. You can check your cell phone to make sure that it is Bluetooth compatible by looking in the settings. There should be an option for Bluetooth listed. Click on it and ensure that it is set to "Allow other Bluetooth devices to find me."
Jan 28, 2011 | Motorola Mobility Universal Bluetooth...
Toshiba laptop with IOgear bluetooth adapter installed will recognize phone but won't detect plantronics explorer headpiece. I would like to use it to chat on skype
If the Bluetooth adapter can detect the phone but not the Plantronics headpiece, then there's no problem with your computer or your Bluetooth adapter. The problem has something to do with the Plantronics.
Try to turn the headpiece off, then turn it back on. Set it to discovery mode, then try to detect it using your computer. If that did not help.
Try to detect the Plantronics, using your phone. That will help you in isolating the problem.
Aside from that, make sure that no possible wireless interference while you're searching for the headpiece. Cell phone, base of the cordless phone should be away from the computer while you're searching for the headpiece. Because Bluetooth and cellphones/cordless phones are running on the same 2.4GHz frequency RF signal. They might interfere with each other.
Apr 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I don't know what model Motorola bluetooth headset I have but I don't know how to get it into discoverable mode to sync it to my phone.
Most Motorola headsets automatically go into pairing mode when you turn them on. If you have a light on your headset, it will be pink when you turn it on (and will begin flashing) and then change to blue. When the light is pink it is ready to pair. If you don;t have a light on your headset, it will stay in pairing mode for 10-15 seconds.
Turn your headset OFF then, (with your phone turned ON) in your phone's menu (usually) you'll go to Settings > Connectivity > Bluetooth (and select ON) Then select, Search for Bluetooth Devices and at this point you want to turn your headset ON.
It may take a couple of tries to get your phone to locate your headset but when it does it will identify the headset by the headsets model number when it locates it.
The pairing code should be four zeros. 0000.
Dec 20, 2009 | Motorola Mobility Bluetooth Hands Free...
Motorola h500 bluetooth headset
Make sure the wall socket it's plugged into is on. Some have wall switches that must be turned on to activate the socket. Leave it plugged in over night if you are using it the first time. Plug something else into the socket (like a desk lamp) to make sure it is delivering electricity.
If it still doesn't turn on after attempting to charge with an electrical socket you know works, the product may be defective.
Apr 25, 2009 | OEM Systems Motorola Bluetooth Headset...
Thank you for your help. I was getting very frustrated trying to pair my new Bluetooth with my Nokia 6126. I'm all set now. You're a lifesaver!!!!!
Dec 01, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility Logitech Mobile Bluetooth Over the Ear Headset for RAZR V3c Verizon Cell Phone (980228) Headset Logo
14 people viewed this question
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
