Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
Posted on Oct 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY Rheem 81SV40D Water Heater (47 gal) does not heat enough water. Approximately one bath worth.
Gene Haynes
Level 3:
  • Rheem Master 5,391 Answers
  • Posted on Oct 08, 2012
Gene Haynes
Rheem Master
Level 3:
Answers
5391
Questions
0
Helped
2603949
Points
14124
You have dual-element 240Volt electric water heater.
Since you have some hot water, then we know upper element is good, and that circuit breaker and electricity to water heater are good.
Not enough hot water is probably bad lower element, and possibly sediment build-up in bottom of tank.
Test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace 4500 watt element available at local hardware, and clean out bottom of tank:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3 Related Answers
t1m130
t1m130
  • 86 Answers
  • Posted on Mar 15, 2009
SOURCE: Elec water heater
first turn the breaker off there should be two covers on the font of the heater if you r just looking for adjustments u can take those covers off and there is usually a foam piece behind the covers pull the foam off and there should be a dial to adjust it
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Jan 05, 2010
SOURCE: My rheem water heater doesn't seem to be heating
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
Peter Hampton
  • 193 Answers
  • Posted on Apr 21, 2010
SOURCE: Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Testimonial: "It is very good advice. I bought a tester to check out both upper and lowre thermostat and heating element; I've replaced the lower heating element "
Rheem 81sv40d c water heater not working
Get a magnaclean fitted onto your ch pipes aftr flushing your system.this will prevent the problem in the future
Model 71-52DB 50 gal. water heater stopped heating
Press the reset button located on upper thermostat
Following link has troubleshoot for electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
My electrid rheem hot water heater makes a loud pop sound after using hot water to fill bath tub . Why?
The sound is the water heating through mineral buildup in the bottom of the tank...
The water gets superheated (boiling) because the mineral traps it aroung the element for too long....then it makes the noise as it percolates there....
How to Clean Hot Water Heater
heatman101
1helpful
2answers
RHEEM 40 GAL ELEC TALL Water Heater 6YR SC 82VH402: my rheem 81sv40d water heater quit heating water. ...
I have the same problem about every 3-4 months. Mine is also about 10 or 11. It is usually the sediment at the bottom that causes this. Once the plumber flushes it, it works again. My problem is that I dont know how he did it and the vavle is at the floor level. I am never home when it is repaired. Regular maintenance (flushing) is how you avoid this from reoccurring. That is, if that is the cause of your issue.
2helpful
1helpful
2answers
Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
1helpful
My rheem water heater doesn't seem to be heating the water. I have a Rheem model 81SV40D and the water is not hot and doesn't seem to get hot. I have checked the dials on the water heater and they are set...
1helpful
After about an hour the breaker trips on a single element Rheem water heater. 2Meg ohm to ground from the element terminals: 700K between element termianals. theromstat connections to ground infinate. (can...
I would say then the heating element has a resistive short to ground. The 1.98m Ohm reading is high, but not high enough -- should be infinite. I would say replace heating element... And, when you install new one, make sure there is no water leaking thru heating element cavity and ensure area around cavity is clean & "in order".
How old is water heater?
Charlie
Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
