Question about Canon imagePROGRAF iPF8000 Printer
My power supply is damage - Canon imagePROGRAF iPF8000 Printer
ERRO
exiting tally
file :D:/chitsons7backup\tally72\dats\0003\manager.500'
position:347008
chars:128(done0)
pls help me
Posted on Dec 30, 2008
My epson 340 has no power
You have to disassemble the printer and check the power supply. Make sure that the fusehas not blown or some other component is damaged. If there are damaged components,to remedy these switching power supply components.
If the power supply is working perfectly, Check all the connections of the logic board andpanel board looking for damaged cables.
Apr 10, 2012 | Epson Office Equipment & Supplies
I have done all that you saud to do. Now the problem I have is the computer will not turn on at all. It's like the power has been turned off from inside the operating progam. I have windows 7, is this...
Phase 1
After power button pressed, computer will detect 5 components :
1. Power supply - OK (enough power)
2. Main-board - OK
3. Processor - OK
4. Memory - OK
5. Video Card / VGA - OK
== beep sound .. (1 time) or on the monitor, display appears BIOS ==
The characteristics of damage to power supply
1. Power supply fan does not spin
Video power supply fan not spinning
If the power supply fan is not spinning, the possible cause of damage to power supply. Solution, replace the power supply.
How to check the damage to power supply
2. Power supply is weak (resulting voltage power supply can not turn on the computer or the voltage is less)
The characteristics of damage to the processor
Normal fan without processor
Normal fan with processor
Based on experience, the possibility of damage processors is very small. To check for damage to the processor, install the processor to another computer (for comparison).
The characteristics of main-board damage
Because the new main-board, so the possibility of the main-board damage, very small. The characteristics of damage to the main-board, when the power button is pressed
1. Power supply fan not spinning
2. Processor fan is not spinning
3. Casing lamp is not lit
4. Main-board lamp does not light
The characteristics of the memory damage or dirty memory
1. The characteristics of normal memory, but installation is not correct or dirty
When the computer is turned on, the sound
Solution
Picture a
Release Memory
Picture b
Clean the memory slots with a brush
Picture c
Clean the gold layer memory with a pencil eraser
Picture d
Reinstall the memory correctly
The characteristics of damage to video cards
Solution, remove the video card, clean the gold layer with a pencil eraser.
I hope this information helps.
Oct 23, 2011 | Computers & Internet
My Power supply burned cause my brother Plugged it in the New zealand power,....Im from the STATES,...What makes me concerned is that im afraid that my console is Damaged,...Please tell me its not...
Welcome to Fixya
Looks like you have a burnt power supply. Burnt power supply wont damage the console. Purchase a new power supply and problem will be solved.
Thank you for using Fixya!
Sep 29, 2011 | Microsoft Xbox 360 Console
In asus P5GL-MX mother board the power supply regulator ic 2 piece has been damaged (short) how would i know plz help me
Hi if the regulator ic has been damaged in your power supply even you replace that there are some electronic component where also damage because the ic will not damage where there is no over voltage flow on it. This means there are some resistor or a transistor is also shorted it advisable to replace a new one than to repair your power supply. Because even you repaired it the performance and the life span of your power supply is not stable. So it better to replace a new one.
Jul 14, 2011 | ASUS P5GL-MX Motherboard
A585 base unit as no power since thunder storm last week
Check your power supply.It appears to have been damaged by the Lightning,for a quick solution,smell the power supply and if it smells of burnt carbon,you can be assured it is damaged and needs to be repaired/replaced.Pray that you dont have damage to the equipment that was connected to the supply.
Jul 04, 2011 | Cell Phones
Lightning storm & power went out for about two seconds. PC plugged into surge protector but would not go back on. Found that surge protector blew and was no good. Got another and plugged all back in...
Your reasoning about the switch mode power supply being damaged is probably right.
Bear in mind that this power supply may not be the only thing that may be damaged in your computer.
You won't know for sure until you borrow a power supply and install it into your computer to see if it will work again.
Jun 18, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Hp 763n, the computer crashed and I got a bad burning small for the 200w power supply. Do you think any other damage was done or I could just replace the power supply?
Hello
Usually The motherboard and other components are protected by the power supply first.
So no i doubt you have any other damage.You need to consider what caused the power supply to burn up.Maybe you need a bigger one.
Have a good day.
Apr 29, 2010 | Computers & Internet
Power surge, TV will not turn on
Power surges are extremely unpredictable, they can damage everything inside the tv, from the power supply printed circuit board, to the main printed circuit board. Normally the power supply takes alot of the damage from these things, so check over the power supply for any damaged components, any burnt out parts on printed circuit board, and also check the fuse. Good luck.
Aug 28, 2009 | AOpen Televison & Video
The power supply don't operates - INFOCUS X1
Usually the projector bulb, try to replace it first but I will not recommend you to do so but it is your decision.
Nov 21, 2007 | InFocus POWER SUPPLY CORD Multimedia...
Canon imagePROGRAF  iPF8000 Printer Logo
124 people viewed this question
old marine
old marine
