Question about Anthology Solutions Yellow Machine P400T (250006001) 400 GB Network Hard Drive
Yellow machine server.
I am having yellow machine p400T.
if i switch it on.
the fault LED starts blinking.
the WAN port is not working
pl help
  • Anonymous Jan 16, 2009
    I have the same problem, have you found a solution yet?
  • 478 Answers
Is it just the fault led, let the machine run for a while and see if it starts rebuilding the drives, if it is NEW and you have just installed the drives and never installed the software then you will get a fault I have the q400t which is the platnum version tho they still call it the p400t if you have just received the server then what u must do is power off the server plug in the netcable into one of the 8 lan ports run the install till it tell's you to turn it on then hit next then follow the instructions to setup the server
Posted on Apr 28, 2010
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Yellow machine power out won't restart
You will have to get a disk recovery specialist to retrieve your data. The internal YellowBox system is Linux. The specialist will remove the disks and attach them to translation and recovery technology. It will cost money.
Dec 19, 2013 | Anthology Solutions Yellow Machine P400T...
I'm looking for software for my yellow machine p400t
I have the last update disk 3.3 and would be happy to upload it to a file sharing site for you.
Jun 04, 2010 | Anthology Solutions Yellow Machine P400T...
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
Unable to acces yellow machine p400t
Set your PC networking to Obtain IP Automatically and see how you go
Nov 26, 2009 | Anthology Solutions Yellow Machine P400T...
My server blinking yellow on led harddisk indicator led
which model server you have this may be hardisk fault just remove the hard dive and fix it agian.
Sep 09, 2009 | Dell Computers & Internet
Router not picking up i0 address
If you have cable internet then you need to :
* disconnect router from cable modem
* restart the cable modem (power off-on)
* restart the router (power off-on)
* connect cable modem to router WAN port using CAT5 straight cable
If problem still exist try changing the cable to new one. If it still does not work then contact your ISP
Jun 08, 2008 | NetGear WGR614 Wireless Router
How do I set up the P400T Platinum to be used as a Domain Server?
You can configure it through the web GUI.
The unofficial support website is: http://www.yellowmachinesupport.com/
The manual there will give you the info. I'm not sure it will do ddns.
Good luck,
David
Mar 25, 2008 | Anthology Solutions Yellow Machine P400...
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Wireless keyboard & mouse not working
First download and run regscrub xp and ccleaner to clean up your system then try uninstalling and reinstalling the logitech setpoint software and try the keyboard and mouse again. Let me know if this works.
Oct 23, 2007 | Logitech Wireless Access Duo Optical...
Anthology Solutions Yellow Machine  P400T (250006001) 400 GB Network Hard Drive Logo
251 people viewed this question
Top Anthology Solutions Computers & Internet Experts
David Payne
David Payne
Are you an Anthology Solutions Computer and Internet Expert? Answer questions, earn points and help others
