Question about Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
How to print envelopes
How does one print envelopes on the brother mfc 8660dn printer? Where do you insert the envelope?
  • Anonymous Mar 22, 2014
    printer prints blank envelopes
Open the manual feed tray door (that is the door on the front that has the "Brother" logo on it. Narrow the feed tray guides to filt your envelope. Envelopes feed it with flap side up and to the left.
Posted on Feb 09, 2009
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
I have a brother HL-2140/2170W Monochrome Laser Printer and don't know if I can print envelopes from this printer. It doesn't appear to have an envelope feeder.???
It can cause creased envelopes when printing on envelopes......but if you consult the manual there are fuser tension adjustment switches that solves that for perfect envelope printing (Settings, A, B and Envelope).
http://www.iusermanual.com/printer/brother-mfc-9840cdw-multi-function-printer-manual.htm
hi at this above site you can download your user manual, this shows you in detail exactly how to print on envelopes.
below is a Brother "How to" It's very informative.
http://welcome.solutions.brother.com/BSC/public/as/nz/en/faq/faq/000000/000000/000063/faq000063_033.html?reg=as&c=nz&lang=en&prod=mfc9840cdw_all&Cat=103
Dec 20, 2010 | Brother MFC-9840CDW Laser Printer
Brother 7340 wont print on envelope just keeps getting stuck, tried opennig the back like the book says but still gets stuck
Are you trying to print from the main paper tray with the envelope or from the auxiliary single page feeder? The auxiliary insert should be directly under the "Brother" logo on the front of the printer. Insert the envelope there. If it's a standard light weight envelope and it gets stuck still then I'd suggest there is a paper jam somewhere or possibly the fuser is going bad.
Oct 29, 2010 | Brother MFC-7340 All-In-One Laser Printer
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Aug 11, 2010 | Brother MFC-465CN InkJet Printer
Can't address envelopes using Microsoft Word 2007 & Windows 7
Excellent question. Wish I had the answer. I have the same problem with the MFC-7440N. I hook up my old HL 1240 and it prints them fine, so I now use two printers - one for envelopes and one for normal printing. I contacted Brothers and was told that it was not the printer, but the Application. If so, then why does my old Brothers printer work? They do not have the answer.
Feb 24, 2010 | Brother MFC-7440N Laser Printer
How do i print envelops on my brother MFC 866oDN printer
You will need to use the manual feed slot, located above the paper tray
Feb 21, 2010 | Brother MFC-8660DN 5-in-1 Laser...
Wrinkled envelopes Brother mfc 9840cdw
Instead of moving the whole green lever to adjust that grey arrow to the envelope symbol, simply push the gray part that has the arrow on it. This will move the gray piece down to the env. symbol and will not move the green lever so you can close the back door. I used to have severly wrinkled envelopes. Now they print out perfect.
Sep 25, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW wrinkles envelopes. Brother says this is "normal", and that the only way to 'fix' it is to open the back of the printer EVERY TIME YOU PRINT AN ENVELOPE and make some kind of...
Problem Solved!
I have a Brother MFC-8480 DN all in one printer, copier, fax and scanner.
I discovered that envelopes wrinkle because users, like me, didn't know that Brothers built in a no-wrinkle, pass through exit for envelopes, labels and thick paper.
Envelopes were never to be printed by inserting them in the front and letting them wrap around a HOT roller and get cooked and wrinkled. The way it works:
An envelope is inserted in the front and goes straight out the back of the printer through an exit door, completely avoiding the hot roll-through mechanism.
Take a look. On the back of the machine is a large pass through exit door. Just snap it open. You will see one blue lever on each side of the opening. Snap them both straight down to the . . .ta da. . ."envelope icons".
Put three envelopes in the front and they will print straight out the back, perfect and wrinkle free. After printing your envelopes, snap the blue levers back up and shut the door. Takes about five seconds to open the door and snap down the blue levers down/up.
Happy envelope printing.
-Eric
Jul 11, 2009 | Brother MFC-9840CDW Laser Printer
Printing envelopes
Use the tray 1(manual tray ) to print on envelopes.
Apr 27, 2008 | Brother MultiFunction Center MFC-440CN...
Printing envelopes
Pull down the front and slide the paper guides together till they are the size of the envelope. Place your envelope front side up (return address will be at your bottom left)
Apr 01, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
1,012 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
