Question about Pioneer DJm500 Professional DJ Mixer W/Effects System
PIONEER DJM500 CHANNEL SELECT SWITCHES STUCK
HI,ON MY DJM500 2 OF THE SWITHES, CH-1 AND CH-3,HAVE STOPPED WORKING.HOW MUCH WOULD THIS COST TO REPAIR? COULD YOU REPAIR IT? WOULD I BE ABLE TO PURCHASE PARTS TO FIX IT? I AM IN BEDFORDSHIRE UK
Take your headphone jack converters and use large converter and plug into the channel 4 submic. take cord off of basic technic stereo dh1200. detach cord and plug into ipod, then into converter and push PLAY wohooo. Music will come out of whichever assign A or assign B knob channel you set it too. If you don't know where that is. It is close to the crossfaider.This is for a DJM-500.
Bravo to ZOE,
www.whitecollarcrew.com
Posted on Jan 24, 2009
Take it in to Guitar center and they will teach you how to sendc it in to the manufactior or how to buythe parts and replace your self .. pretty simple.. you dont want to take aprart thow then the manufator wont fix for free.. pioneer is good qulity and they will fix....
Posted on Mar 15, 2009
Hi guys, I have a DJM500 mixer which has been a trusted friend over the years but unfortunately channel1 ( CDline/ line) only produces a level on one side only, the other is totally dead. Would appreciate...
It sounds like you have a broken slide switch, the switch that changes the signal between CDline/line. Is is quite a common failure for these Pioneer mixers after a few years of use.
The spare part is this: http://www.artaudioparts.com/product/dsk1044
If you decide to fix it yourself, be advised that it requires a fair amount of disassembly work and some desoldering/soldering skills.
Aug 05, 2013 | Pioneer DJm500 Professional DJ Mixer...
During an attempted Robery two of my (DJM-500) input selection switches on channel 3 & 4 got damaged. Where can I find replacement switches? I can replace them myself.
sorry to hear i contacted pioneer for you not an easy part to find if you send me a picture of the switch i can match it to tens of thous that we order cheers
sonicboomelectronics@hotmail.com
Dec 29, 2010 | Pioneer DJm500 Professional DJ Mixer...
2 of my channels are crackling and 1 is missing how hard is it to replace channels on a djm500
IT IS A SINGLE CARD THAT ALL CHANNELS OPERATE THROUGH NOT A HOME JOB NEEDS TO GO TO TEC TO BE REPAIRED
Nov 03, 2009 | Pioneer DJm500 Professional DJ Mixer...
I HAVE DISTORTION SOUND FROM MY PIONEER DJM 500 MIXER
The first thing that comes to mind is that these units usually use op-amp ICs for buffers on the output lines. These ICs are either defective, or you have lost one of the power supplys. In any case, this is not a simple thing to trace without some test gear. I suggest that you bring this to an audio repair shop. If the ICs are defective, they cost less than $1 each and you will need at least 2.
Dan
Sep 14, 2009 | Pioneer DJm500 Professional DJ Mixer...
Pioneer car audio amp GM 6300F (new)
Does your amplifier have a Channel swith which says 2/3/4 channel mode. If so and you are running the amplifier in Bridged mode, try changing the setting to 2 channel or Bridged mode.
Aug 20, 2009 | Pioneer GM-6300F Car Audio Amplifier
Pioneer DJM500 Mixer - Bass EQ Control on Channel 2
You might want to clean the exisiting potentiometer with dielectric solvent. This might work without having to replace the Pot. But if you have to replace it, make sure you have the correct tools. This is a fine soldering job, but it appears you have the correct part.
Apr 07, 2009 | Pioneer DJm500 Professional DJ Mixer...
Pioneer DJM 500 Ch 2 Bass Controller
The bass pot's / controls are notorious for becoming dry jointed, all that is usually needed is the controls resoldering.
http://www.technicsdjuk.com/
Apr 01, 2009 | Pioneer DJm500 Professional DJ Mixer...
I have a pioneer gm-x404
The wiring is fairly straight forward. Along the top row of the ten pin plug =
(Left to Right)
Front Left positive,
Front left Negative,
Control wire from your stereo head unit should be thin blue wire sometimes listed as Remote Wire this switches your amp on and off via your head unit so you don't run your battery flat,
Front Right Negative,
Front Right Positive.
Bottom Row=(Left to Right)
Left Back Positive,
Left Back Negative
Centre Nothing
Right Back Negative
Right Back Positive
These are all inputs from your head unit.
To bridge from 4 channel to 2 you connect
one left speaker to Ch B Left Positive and Ch A Left Negative
one Right speaker to Ch B Right Negative and Ch A Right Positive
Ten Switching the Input Select switch to 2CH
Alternatively if your unit has RCA's on the back of the Head unit you can use them to run your subs.
Hope that helps.
Feb 28, 2008 | Pioneer GM-X4 Car Audio Amplifier
Static out of 1 MASTER OUT & channel selector for effects is not working properly
umplug your system from the main electricity outlet and spray the knobs with connection spray. it think it is just just in there. good luck
Sep 27, 2006 | Pioneer DJm500 Professional DJ Mixer...
Pioneer DJm500 Professional DJ Mixer W/Effects System Logo
180 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
