Question about Epson LX-300 Matrix Printer
Driver problem i have a LX 300 + .... when i install the driver of this printer .. the test page does not print ok .... but when i installed the LX 300 Driver ... it print all the document in ok ...... i want to install the orignal deriver and print the documents ... as it gives me problems in my other softwares ... i am using XP as OS ...
    Novelist:
    Champion:
  • 254 Answers
You may have to come to a happy medium on this printer, or, perhaps there is a dip-switch setting (on the printer) needing to be changed. You could also try one of the other Epson printer drivers. Perhaps you can find one which will get the desired results
Posted on May 01, 2007
Instal printer lx 300 to usb, can,t print?
To make sure that printer is detected then do following things.
Before going for deep trouble shooting please make sure following things:
Ensure that USB cable is Plugged properly on both side.
You can swap USB cable to other USB Port.
Ensure that Printer is ONLINE and Paper is loaded.
If above mentioned things are propter then follow below mentioned steps.
1. Keep The printer ON and remove Usb cable and re plug in Computer.
2. Check on System Tray (near Clock) check that Printer is Detected. or you can check this by Checking in Device Manager. You can open Device Manager by Right Clicking My Computer>> Property>> Device Manager>> Hardware Tab.
3. If device found detected then Open "Printer and Faxes" from Control Panel.
4. Right Click your Installed Printer lx300 icon and click on property.
5. Click on "Port" and ensure that Check Mark Should be on "USB00..xx" not on LPT.
6. If Check Mark is on USB00..xx"" then try to give Test Page.
7. If test page is not printing then try by complete removal of Printer Driver and Re-Install It.
Mar 28, 2010 | Epson LX-300+ II Matrix Printer
My epson LX 300+ was already installed but will
First, you must install the driver of lx-300+. open control panel, printer n fax then find epson lx 300+. Don't forget to test what port that your lx-300+ support. LPT1. Then print test page...If your printer run... it's finish... you have succses instal the printer...
Jul 19, 2009 | Epson LX-300+ II Matrix Printer
No print out
The printer driver maybe corrupted, go to Printers and Faxes and delete the printer then go Add printer and install the printer again.
Apr 01, 2009 | Epson LX-300+ II Matrix Printer
Not install for windows vista
In any Windows environment, the printer itself becomes a dummy terminal and all changes to the printer will be over-ridden by the application or the operating system.
Windows Vista should automatically detect and install devices attached to the computer. Simply connect the printer to your computer and power it on.
If the driver does not automatically install, you can follow the steps below to install a resident driver which is part of Windows Vista. The resident driver installation should only be used if the printer is not detected and installed.
1. Click on START, CONTROL PANEL and PRINTERS.
2. Click the ADD PRINTER button. If you do not see ADD PRINTER, right-click in the PRINTERS window and select ADD PRINTER from the menu.
3. The ADD PRINTER wizard window will appear select Add a Local Printer.
4. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
5. In the next window select EPSON under Manufacturers and your printer model under Printers.
6. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
7. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
8. Once the test page has printed, click FINISH to exit the wizard.
*NOTE: Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
To make adjustments to the output quality and speed in Windows Vista, please do the following:
1. Click on START, CONTROL PANEL, and PRINTERS.
2. Right click on the printer icon, and choose PRINTER PREFERENCES.
3. Click on the ADVANCED button in the bottom right corner.
4. Click on the GRAPHICS option and click the down arrow.
5. Choose the lowest number to drop your resolution and pick up your speed.
6. Click on PRINT FEATURES and choose the option HIGH SPEED ON.
7. Click OK to apply the changes.
8. Once again right click on the icon for your printer, and choose the PROPERTIES tab.
9. Click on the ADVANCED tab and click on the button called PRINT DIRECTLY TO THE PRINTER.
10. Click APPLY (if applicable) and/or click OK to apply the changes.
The driver you are using is a graphics driver and may not have the adequate speed for your purposes. In Windows VISTA there are more basic drivers which respond better to custom page sizes and speed adjustments. Windows also has a driver called GENERIC TEXT ONLY which is made as a universal driver for all printers just for speed. To add in either of these drivers please do the following:
2. In the left hand column choose the option ADD PRINTER. The ADD PRINTER WIZARD comes up, click on NEXT.
3. Select Add a Local Printer.
4. Click on NEXT.
5. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
6. In the next window select EPSON under Manufacturer. Please use the guide below to select an appropriate Emulation driver. If you wanted to install the Windows universal driver, choose GENERIC under Manufacturer and choose TEXT ONLY, click NEXT.
EPSON LQ SERIES (136): Used for LQ wide carriage printers
EPSON LQ SERIES (80): Used for LQ narrow carriage printers
EPSON LX SERIES (136): Used for LX wide carriage printers
EPSON LX SERIES (80): Used for LX narrow carriage printers
EPSON FX SERIES (136): Used for FX wide carriage printers
EPSON FX SERIES (80): Used for FX narrow carriage printers
7. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
8. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
9. Once the test page has printed, click FINISH to exit the wizard.
Jan 22, 2008 | Epson LX-300 Matrix Printer
Lx 300+ detected by xp but test page fails
hello,
please go to bios setting and change parallel port type spp+epp or epp or normal try to change type and try again.
Oct 14, 2007 | Epson LX-300 Matrix Printer
Problems installing a printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
177 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
