Question about Dell Latitude C610 Notebook
I would like to install bigger memorie in my latitude c610, how do i access the slots ?
    Scholar:
  • 58 Answers
Http://support.dell.com/support/edocs/systems/latd600/sm/upgrades.htm#999869
Memory Module, Mini PCI Card, and Modules Dell™ Latitude™ D600 Service Manual
I would like to install - bullet.gif Memory Module
bullet.gif Mini PCI Card
bullet.gif Modules
Memory Module CAUTION: Before working inside your Dell™ computer, read the safety instructions in your System Information. caution.gif CAUTION: Toprevent static damage to components inside your computer, dischargestatic electricity from your body before you touch any of yourcomputer's electronic components. You can I would like to install - note.gif touching anunpainted metal surface. note.gif NOTE: Memory modules purchased from Dell are covered under your computer warranty.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Turn the computer over, loosen theI would like to install - upgrade7.jpgew from the memory module cover, and lift the cover.
  3. notice.gif NOTICE: To prevent damage to the memory module connector, do not use tools to spread the inner metal tabs that secure the memory moI would like to install - notice.gifol>
  4. If you are replacing a memory module, remove the existing module.
notice.gif NOTICE: Handle memory modules by their edges, and do not touch the components on a module.
    1. Use your fingertips to carefully spread apart the securing clips on each end of the memory I would like to install - upgrad10.jpgctor until the module pops up.
    notice.gif NOTICE: If the memory module cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    1. Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
    2. Turn on the computer.
    As the computer boots, it detects the additional memory and automatically updates the system configuration information.
Posted on Dec 30, 2008
I have a dell c610 laptop, and want to put in a 3d graphics card, what do you recommend and can it be replaced?
because this is a laptop you can only upgrade a couple things, and video is not one of them. You can upgrade memory or install a bigger hard drive but that is all the options you get.
Sorry
Nov 26, 2010 | Dell Latitude C610 16MB ATI Mobility Video...
I have 2 memory modules to increase my memory. How do I access the memory ports to insert/change them?
normally ther is 2 panels on the bottom of the laptop both can be removed by unscrewing them. one will give you access to the hard drive and wireless card , the other to cpu and memory slots
Feb 05, 2010 | Dell Latitude C610 Notebook
Dell Latitude keyboard issue
It is the direct access button, it (originally) is to run Dell utilities installed on the system. Generally it is ignored by most users. In theory it can be reprogrammed in Control Panel, Keyboard Properties, Direct Access Tab
Jul 01, 2009 | Dell Latitude C610 Notebook
Dell latitude c610 memory location
On the bottom of the laptop there is an access door held on with a Phillips head screw, actually there may be more than one door.
If you remove the screw and the door, you will see the memory modules.
Here is a manual that has it illustrated for you
Click here.
Mar 21, 2009 | Dell Latitude C610 Notebook
How do i install a wireless card in a dell latitude c510 c610?
It should have a slot on the side of it if it doesn't then you will have to install an internal card
Feb 27, 2009 | Dell Latitude C610 Notebook
My Dell C610 won't reconize the second stick of 256 mb memory
where did you get the memory?
If it is in properly and does't work,it is either bad or the wrong part number for your Dell C610
Nov 27, 2007 | Dell Latitude C610 Notebook
Does not start
Did you recently add a memory..?If yes Then remove it because a frequency mismatch can cause this problem...Another possibility is that the Memory may be oxidized at the end..If this happens then remove the memory and rub the edge(the side which you plug into the slot) with an eraser and then put it back...There's another possibility that the memory slot on the motherboard may be damaged..So try plugging the memory into the other slot and try again...Let me now what happened...
Oct 19, 2007 | Dell Latitude C610 Notebook
Black screen say unsupported memory , remove the unsupported memory from socket 1
I think you might have a faulty memory module. The socket where you push the PC card is not the Socket 1. I think the notebook is complaining about the Memory socket witch you can access if you remove the memory cover(click for details) on the bottom of the notebook. Try reseating the memory module, remove it from the socket and install back. Make sure the memory contacts are clean and not oxidized; clean them with an eraser if they oxidized. Try moving memory from one socket to another. If you have two memory modules installed, remove them one by one and test the notebook with only one module installed. Find out which module is bad.
Dell Latitude C610 Notebook Logo
172 people viewed this question
Alun Cox
