Question about Neff 24 in. S5456 Built-in Dishwasher
Dishwasher not draining (neff slimline intergrated)
After a wash the water does not drain is there a wy of unblocking without pulling out machine
I had this problem and eventually after trying everything short of pulling the dishwasher out and checking the hoses I tried Finish Dishwasher Cleaner. Much to my surprise, IT WORKED.
Posted on Feb 23, 2009
    Problem Solver:
  • 11 Answers
You could try liquid plumber but i wont guarentee anything. However, It could be a problem with the draining mechanisn and not a blockage. Also if the liquid plumber does work I would run the machine with nothing in it to rinse all the chemicals out
Posted on Dec 30, 2008
My dishwasher takes water but does not start to wash it pumps the water out and takes new water and that's going forever
SOUNDS LIKE THOSE LITTLE ROACHES GOT INTO THE CIRCUIT BOARD AND FRIED IT.
MAIN CIRCUIT BOARD HAS BEEN SHORTED OUT
Apr 30, 2012 | NEFF S54T09X1GB Fully-Intergrated Full...
E 15 problem code on Neff dishwasher
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.Turn the main water supply and main power offE15 error means the anti-flood system as activated; you havehad an overspill of water into the base plate below the sump.
If you take the kick plate off from below the door youshould be able to access the base to remove any excess water.Behind your kick board is a plate below the door. Remove theplate.
With the power off push a rag into the base plate to soak up the water.
Failing that pull out the dishwasher onto the floor and tilt the machine backto allow the water to run outSwitch the water and power back on and restart the programto test.If the appliance is less than 2 years old Neff/Bosch Groupguarantees it
Apr 07, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Neff s4459n2 dishwasher not draining the water
It is so common that the drain does not work in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has not drained then the drain hose pump/valve and fittings which are located on the underside of the machine must be checked. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve,, check the voltage on the drain pump during the cycle . If no voltage is present the program controller can be faulty.
Apr 19, 2011 | Neff 24 in. S5456 Built-in Dishwasher
Hi, I have a 10yr old Neff s5543 built-in dishwasher, it is has been working fine but recently has stopped fully draining. I have removed it from the housing and checked all pipe work is unblocked and...
Hello there and thank you for choosing fixya
Ok there are acouple of things that can be checked on this along with what you have already checked
Drain solenoid Beneath some dishwashers, there's a timer-activated drain solenoid (an electro-magnetic coil) that opens a drain valve, to drain the wash water through a hose and out to the house's plumbing waste system. If this is failing it will not allow the water to drain from the machine fully
Timer Dishwashers have a timer behind the main control panel at the front top of the dishwasher, or behind the lower access panel. It is either a mechanical device like a simple clock, or it's completely electronic with just a digital readout. The timer runs the dishwasher in a pre-determined pattern. It provides the electricity to all of the dishwasher components at the correct time, for the correct length of time.
Oct 16, 2010 | Neff 24 in. S5543X2 Built-in Dishwasher
Water staying in machine after wash completed
Hello. Generally, the problem is debris in the drain pump or in the drain line which goes from the base of the machine up into the drain under the kitchen sink. Begin by removing the lower panel on the front of the dishwasher and disassembling the drain line there. Be prepared for about 3 cups of water. Then REmove the pump and visually examine it on the inside. If you don't find the debris there check the entire drain tube, and the connection area under the sink. J.
Jul 28, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
May 26, 2007 | Neff 24 in. S5555X0GB Built-in Dishwasher
Neff 24 in. S5456 Built-in Dishwasher Logo
1,069 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
Stefano Andreani
Stefano Andreani
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
