Question about Sylvania SRCD227 27 in. TV/DVD Combo
VHS carriage stuck
When I tried to insert a VHS tape, the carrier was stuck. Instead of pulling the tape into the machine and mounting it on the heads, the carrier got locked down isnide. It took and hour to coax the tape out, and now when I turn on the set, I can hear a smallmotor on the VHS side whirr for a few seconds, pause, and then it sounds like it reverses. It runs for a about three seconds, and then the set shuts itself off. The carrier won't move on it's own. The set stays on for less than 10 seconds before automatically powering off. I felt around inside that narrow little space and could not feel anything broken, detached, or overly loose. The whirring sound seems to come from the front part of the chassis, but I cannot visualize it in the area I can see. We had watched a VHS recorded program just a few days ago and everything worked fine. There were no problems ejecting that tape.
  • Anonymous Dec 10, 2007
    i have the same problem
    Novelist:
  • 114 Answers
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK. PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,... I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE. Joe_Rex
Posted on May 01, 2007
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
My Panasonic VHS Player Model PV-V4020 is locked up so I cannot insert a new tape.
This will be some form of physical damage to the carriage mechanism, that holds the tape. Sometimes it's a simple thing like the flap getting stuck. But often it's a broken piece of plastic.
Apr 21, 2013 | Televison & Video
Cannot load tape. keeps ejecting tape when trying to load.
Remove the top cover from the VCR. If you have children in the house, look for any object lying in the mechanism. If this is clear, insert a tape slowly into the carriage & watch carefully if the cassette tape flap raises up & allows the tape to be lowered down into the mechanism, if not the flap lever at the side of the carriage may be broken. If the tape does lower into position, look to see if the tape is being pulled out by the guide arms, (normally 2 white poles) one of these may be broken. Check the half loading arm is also not obstructing the tape. If any of these parts are broken a new deck mechanism would be required.
Jul 06, 2009 | Mitsubishi HS-U530 VHS VCR
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
Apr 16, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
JVC HR-vp673U
Be sure no foreign object is in the tape well. The other possibility is that the carriage assembly needs work...accordianman
May 11, 2008 | JVC HR-VP673 VHS VCR
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Can't put a VHS in
If the VHS isnt going in it may require a little force as the track might have gotten stuck with dust. if you think its something else i suggest you openj it up and see if these is anything logged in the carriage way or if the tray might just be stuck. once it is open simply insertthe vhs tape and keep pressing in on it until the machine takes it in. while pressing keep you eye on the carriage and see hwat might be stuck as to preven the tape from entering. BUT I THINK IT MIGHT JUST REQUIRE A LITTLE FORCE as it may be binded with lack of use
Jan 04, 2008 | Televison & Video
Neither deck will open to insert tapes in my dual deck vcr
It seems they didnt refirbish it, you should return it..
If for some reason you cant return it.
The problem is your carriage unit is damaged
The carriage unit is the parts that load the tape into the vcr
If you think you are able you can open it up and look if any springs have fallen out. If not then change the unit.
If you cant fix it your self a technician can easily do it for you since it isnt that hard and somplicated to repair, you just need good retainence
Dec 01, 2007 | JVC SR-V10U S-VHS VCR
Tape stuck in VCR
First locate the load and unload motor, it is the one with the rubber drive band. release the drive band and rotate the gear to raise and pull the carriage back into position.
This should remove your cassette, and put the carriage back into position.
Regards,
Eagle
Oct 19, 2007 | JVC HR-J461MS VHS VCR
Can't insert tape into deck
Remove the cover again and move the tape carriage all the way towards the front (the carriage is not fully in the locked position). Once that is done you should be able to load a cassette again.
Sep 27, 2007 | JVC SR-V10U S-VHS VCR
Sylvania SRCD227 27 in. TV/DVD Combo Logo
224 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
