Question about Rolex Daytona 116520 Wrist Watch
My daytona#24 is showing the wrong time,and the top crown is it supposed to be down tight because it's not.
  • 2,071 Answers
Just put a little machine oil,and try to turn the crown and pushing so it lose the tightening,if showing a wrong time reset it,or replaced it with new battery so it works better again.
Hope it may helps you;
Regards;
VOTIT
Posted on Jan 01, 2009
Need to reset the time on my winner 24 it was given to me as a present and they lost the instrutions
If it is a genuine rolex:
  1. You twist the crown counter clockwise to unscrew it.
  2. Gently pull the crown. You should hear it click into the last position. Turn the crown to change the time.
  3. When you are finished, gently push the crown back in towards the watch case.
  4. Screw the crown back down by turning it clockwise.
Nov 04, 2013 | Rolex Daytona 116520 Wrist Watch
I have a diamond encrusted rolex daytona 24 watch, is it real? it has about 200 diamonds on it, if its real how much will it be worth?
A feature of Rolex watches is a solid caseback. The only time an engraving is placed on any Rolex watch casebacks is as an aftermarket feature (i.e "Tom, I love you, Sue").
The "Winner Daytona 24" engraving on the back is, i'm afraid, a common feature of a replica Rolex watch.
Aug 26, 2012 | Rolex Daytona 116520 Wrist Watch
Can a fake daytona winner rolex be fixed
Whatever is wrong with it, it would cost more to fix than it's worth, it has no value really.
Jul 10, 2012 | Rolex Daytona 116520 Wrist Watch
How to set Time in Rolex 116520...thnks a lot
The Daytona's Construction
  • Most stainless steel watches are made of surgical 316L steel, which is very good. Rolex goes a step beyond this, using 904L steel, it is both super corrosion resistant and highly polishable, which is why a Rolex shines like no other. Its bracelet is very easy to size adjust, using screws instead of pins. It is actually made of 100 moving parts that conform to the wrist with smooth edges that never snag or pinch the skin. The bracelet also has the Easylink system which lets you make a further adjustment when your wrist expands due to exercise and high altitudes. Rolex watches were originally intended to be a working man's watch and its construction is shock resistant, antimagnetic and water resistant. It achieves water resistance through its triplock system winding crown.
    You must first turn the watch crown counterclockwise until it releases from its seal. The watch crown will then pull out to let you either wind it or set the time. When complete, you must apply gentle pressure to it and turn it clockwise until it screws back into the case to protect it from dust and water. The Daytona caseback is hermetically sealed and only an authorized Rolex service person will be able to open it.
  • The Daytona's Movement
    The movement of the Daytona has changed over the years, it currently uses a 4130 caliber in-house movement. It is made of 290 parts which is much less than other Swiss chronograph movements. Its smaller size is efficient and precise and lets it fit into to the relatively small 40mm case. Note the size difference between the Daytona and the Tag Heuer Aquaracer. The watch movement also contains a Parachrom hairspring. This device protects the movement from magnetic fields and protects it from shock. On the front dial are the words, "superlative chronometer officially tested." This means the watch has undergone two weeks of testing under extreme conditions to meet Swiss standards. This process is standard for every Rolex with chronometer function. Using the Chronograph
  • The chronograph function can be first and foremost used as a stop watch. To start, press down on the button above the crown. To stop, press the top button again, and to reset press the button below the crown. The chronograph can also be used as a large second hand if you synchronize it to begin with the small second hand at six o'clock of the dial. It can also be used to calculate speed, which is a little more complex. It utilizes the units per hour scale that is engraved in the bezel of the watch. For example, suppose you have taken 50 seconds to travel 1 mile. Looking at the dial you can then determine your speed to be 72 mph. Average speed times can also be determined using further calculations.
  • Any other questions I would contact ROLEX at their website. They even have downloads. Good luck.
    http://www.rolex.com/en#/home/
    Aug 16, 2010 | Rolex Daytona 116520 Wrist Watch
    Need manual for rolex daytona men's watch
    Hello
    These are the things you might need about the watch.
    1. Turn the crown clockwise while it is in position 2 to manually wind the watch.It will stop if it has not been worn out or put in a watch winder for roughly two days.
    2. Pull the crown out one notch to position 3 to change the time.Turn the crown clockwise to move the minute hand.
    3. Push the crown back into the watch while turning it clockwise to return the crown to position 1.The crown should be tight to ensure the watch case is waterproof.
    4. Operate the stopwatch and chronograph function by pressing the button located above the crown on the 3 o clock side of the watch.Stop the stopwatch by pressing the button again,Reset the stopwatch by pressing the button below the crown.
    BEST OF LUCK
    Jul 13, 2010 | Rolex SS/18kt Daytona
    How do i set date and time
    NOTE: NEVER EVER set the date between 7pm and 2am or you will damage the watch!! The crown is screwed down to make it waterproof. Start by unscrewing the crown by turning it counter-clockwise until it pops out slightly. That is position '1' which is used for winding. Pull it out two more clicks to position '3' and set the time by turning the crown clockwise. Turn it past midnight at which point you will see the date change and continue turning till you get to the right time. If you're setting the time to a point after noon, be sure to go all the way past 12 noon before setting the time or the date will change at noon instead of midnight. If the time is before 7pm push the crown in to position '2' and turn it to set the date. When you are finished push the crown all the way in and turn it clockwise to screw it down.
    Apr 28, 2010 | Rolex Daytona 116520 Wrist Watch
    Just bought an Invicta 8926 can't get the crown to pull position 2 or 3. It is screwed down tight. Is it supposed to be turned counter clockwise to release the crown or is it just supposed to pull out...
    Watches vary in design but those that have a high degree of water resistance often screw the crown in.
    Try turning the crown anticlockwise before pulling it out.
    Apr 21, 2010 | Invicta Automatic Watch
    Rolex 1992 daytona watch
    There should be 3 knobs on the right side of your watch. Unscrew the middle knob with the crown on it until it pops out. After it springs out, it will be in winding mode. You want to gently pull it out past this point, it will click into place and you will be able to set the time by turning the knob. After time is set just push the middle knob back in and turn clockwise unitl it is tight.
    I hope this has been helpful,
    dansfinetime ebaa
    Nov 01, 2008 | Rolex Daytona 116520 Wrist Watch
    Rolex Daytona 116520 will not start
    no! you have not done anything wrong my suggestion is bring it to an authorized rolex service center or any certifide rolex watch fixers.to avoid any damage of your rolex daytona. it mabe costly but you have made it wisely.
    Mar 10, 2008 | Rolex Daytona 116520 Wrist Watch
    Date and month
    There are three positions when you unscrew the crown stem. One does the day, one does the date and one does the time. You can also advance the date by rotating the crown stem and advance the time for 24 hours, as if a day passed. That takes a lot longer.
    Sep 15, 2007 | Rolex Daytona 116520 Wrist Watch
    Rolex Daytona 116520 Wrist Watch Logo
    119 people viewed this question
    Top Rolex Watches Experts
    Samyfam
    Samyfam
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
