When turned on, red light flashes twice then goes out. When keeping on/off pressed, I can force the green light comes on, flashes for about 20seconds and goes out. Any suggestions how to fix it? Thanks
In the machine there is small circuit board that control the machine so they programmed that circuit to preheat the heating element for about 30s if this failed the red light flashes two tims then stops so you have to change the circuit board
SOURCE: My krups dolce gusto stopped working. The lights
Hi, Could be a number of things. Is your pump working. Thermoblock maybe blocked or faulty. A thermo sensor on the thermoblock maybe faulty. Brewunit maybe jammed. Descale will not help if it wont pump. Id be looking at the thermoblock or sensor. If their at fault then the machine will do nothing. See how you go and ill keep a look out for any more questions you may have. Dazza Repairer
SOURCE: dolce gusto
Hi. I work at Nestle on the brand and it sounds like either a fuse issue or a clogged needle. Please call our consumer services number at 1-800-746-3391 for assistance. They are open Mon-Fri 8am to 8pm EST.
SOURCE: I have recently bought a
Got the same problem - and im addicted to lungo, I heard you can buy cleaning pods to clean the inside - try checking google !!
SOURCE: dolce gusto lattee machine keeps leaking round the pod area
If its not condensation the seal is gone.
