Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Pretensioning starter cord on ryobi whipper snipper.
How do ito pretension starter cord on ryobi whipper snipper
  • 1 more comment
  • trishaz1 Jan 04, 2009
    posted by trishaz1 on Dec 30, 2008
    how do ito pretension starter cord on ryobi whipper snipper
    Still need a solution for this problem? Try our Premium Assistance plan
    Solution #1
    posted on Jan 03, 2009
    evwood
    Rank: Master
    Rating: 76%, 7 votes
    You said you answered it ealier but I can't find the it where would I look.
  • Anonymous Mar 18, 2014
    my whipper snipper wont start just keeps flooding
  • Anonymous Mar 23, 2014
    shaft which holds the head on a pope whipper snipper has broken away
  • 50 Answers
This was answered in a previous solution
Posted on Jan 03, 2009
Starter recoil spring reload, How?
If the spring is unwound.
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If the starter cord needs a pretension, this works quite well.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 26, 2010 | Homelite Garden
How do i replace a shaft for ryobi whipper snipper
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it.
HTH
Good Day. mate
Oct 22, 2009 | Ryobi Garden
Rob poulan leaf blower how to rewind pull string
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled. HTH
Lou
Sep 05, 2009 | Poulan Garden
Pioneer chain saw mo# p411 starter pull rope does not retract spring came off post and was repositioned how do I ''pretension''
The spool on my Pioneer FarmSaw says 2½ turns clockwise. Remove pull handle, place cord in notch, now it be pretensioned. Feed cord back through cover and reistall handle. Lou
Jul 30, 2009 | Garden
I have a poulan p3315 14" chainsaw. The the recoil won't work. I took the assembly apart and I can't get the recoil spring back in. I would like to buy a new assembly. Do you know where I can buy one?
Poulan.com Look your saw over carefully and maybe you'll find a model number that matches one of these.
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Jul 18, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My recoil inside the pullstart
Jun 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Broken recoil spring
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to pretension starter cord on ryobi whipper snipper
Remove the housing and pull the cord partly out. Then rewind the rest. Check to see if it retracts properly. Good Luck!
Dec 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Poulan Wild Thing 18 Inch replace starter spring?
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Oct 09, 2008 | Poulan 1630 16" Chain Saw
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
1,063 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
