Question about Princeton Digital LCD1711 17" LCD Monitor
Princeton LCD 1711 Monitor won't show a picture
The power supply works and I get a green light that my connection is being received but I get no picture! I can see the picture for the first 1/2 a second when I turn on the monitor but then it goes blank. Every time I switch screens on windows I can see the desktop for 1/2 second but then nothing. I have updated to the latest video drivers and tried it on another pc. I get no picture either way.
  • Gerhard Stoll
    Gerhard Stoll May 11, 2010
    Exist the problem the same without booting windows?
    For example when you go into the Bios of the Computer?
    Can you light with a torch (i hope this iss the right english word ;) )on the display - when you see then the picture / windows desktop the backlight is bad.
    Then the backlight power circuite fail.
    More to this thinks you can learn on the book from:http://www.lcd-monitor-repair.com/ that i buyed bevore an short time.
    some greetings from germany
techman
  • 3130 Answers
SOURCE: white screen covers desktop
Ah A simple one. simply unplug the power adaptor and take itno a repair place or radio shack and ask them to measure the output to see if theres 12 volts DC on the plug?? Good Luck
Posted on Jun 14, 2006
guide2u
  • 461 Answers
SOURCE: Service Manual with Schematics for Princeton VL1916 LCD Monitor
this issue might not be because of your Monitor. Anyway, I can only provide manual to this legacy product of princeton if you want...
Posted on Sep 06, 2007
sibleyson
SOURCE: Princeton VL1919 repeatedly pops when turned on
If you feel confident take the monitor back cover off and replace the 3 bulged out capacitors
Posted on Feb 01, 2008
SOURCE: PRINCETON LCD-15BLK MONITOR
ya mum
Posted on Feb 08, 2008
viziks
  • 220 Answers
SOURCE: Acer 1711 monitor won't power up
power supply of the monitor is the culprit.Generally defective electrolytics in primary section of Power supply.
Posted on Feb 19, 2008
Describe your (VL1916) 19" LCD
Did you try this monitor with another PC and already verify that the VGA cable is OK.
Common problem with Princeton monitors are due to bad DC filter capacitors in the power supply board, see example here:
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
Sep 10, 2011 | Princeton Digital VL1916 19" LCD Monitor
Sep 06, 2007 | Princeton Digital VL1916 19" LCD Monitor
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Monitor has no power to it. The power cable and V...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Princeton Digital LCD1711 17" LCD Monitor
I have the princeton VL193 monitor. Its blank, no power light
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 14, 2010 | Princeton Digital VL1916 19" LCD Monitor
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
HL710S Daewoo Monitor
I HAVE A 17 INCH MONITOR AND IT WONT POWER ON MY POWER WENT OUT AND NOW IT WONT POWER ON AFTER POWER WENT BACK ON
Mar 28, 2008 | Princeton Digital LCD17 17" Flat Panel LCD...
Feb 18, 2008 | Gateway FPD2275W LCD Monitor
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
Sep 27, 2007 | Princeton Digital VL180 18.1 in. Flat...
Power issue with LCD Monitor
Try another power adaptor. Check the delivered voltage and go get a universal power adaptor that has a switched for varios voltages and a number of connectors. Simply match connector to the voltage switch.
May 21, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
Princeton Digital LCD1711 17" LCD Monitor Logo
182 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
