Question about Veo Stingray
Webcam resolution/color problem
Something went wrong in my settings and i can't get my webcam back to the right color. i've tried trial and error but to no avail. the color has gone from green to yellow to blue...but i can not get it back to the right color. as of right now, it's all black with hints of green. it all started when i clicked on the settings tab and i'm not quite sure which settings i changed, but at one point it went green and upside down. i got it to go back up right side up, but i can not get the colors to go back the way they were. the only steps i've taken is to try and fumble around with the settings. Can someone please help me get the settings corrected? thanks!
  • Veo Master
  • 10,322 Answers
1st You download Webcam Driver.
Webcam Drivers After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Veo Camera Drivers for Windows XP Vista Windows 7
Posted on Mar 05, 2014
    President:
  • 2,961 Answers
Unless the camera itself is faulty, the only other thing to do is to uninstall the camera driver in add/remove programmes and re install the software again and give it a try and if possible put the camera in a different usb port.
Posted on May 01, 2007
The display on my toshiba nb505 went to the right of the screen. I can't reach the close x with the arrow anymore. What did I do wrong and hoe can I get the display to go back to normal ? Thanks in...
This is a common problem on net books. You can try playing with the resolution until the picture fits the screen again (that is often a resolution setting issue). To find resolution setting, right click anywhere on the desktop and click on 'properties', or 'personalize', whichever it shows, then 'Display' in bottom right corner. Good luck.
Feb 11, 2014 | Toshiba Turquoise 10.1" NB505-N508TQ...
My display driver R3000 or w/e, messes up like everyone elses, but not while im on yourube..only while im on World Of Warcraft.. ive spent months trying to fix the problem..ive done everything i believe i...
It is possible that your VGA is malfunctioning. But you will notice it when the screen resolution is set to a specific resolution and color depth.
Games play at it's own resolution. Not at the resolution you set for Windows. Probably WoW is setting the screen resolution and color depth to a values at which the VGA fail.
Did you try changing the screen resolution in WoW options? If not try it. Also try changing color depth.
Also, download GPUZ and check your VGA.
Best of luck!
Aug 20, 2011 | Toshiba Satellite A135-S2276 Notebook
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
When tried to open HP Media Smart to use webcam, is says cannot open and says something about display resoution and even tried with all the possible display resolution. Any suggestions will be...
Your screen resolution need to be set i am not sure what operating system are you using but you can right click on the screen/ desktop, click on property, click on settings then you will set the resolution to either 1024 x 768 if you still have the problem you can set it to 1280 x 768 this should solve the resolution problem. As for the webcam and the hp media smart you should uninstall and reinstall the software/driver for the webcam and the hp Media Smart if you have the CD with the drivers/software you can use it to reinstall the drivers on the computer this should solve the problem.
Dec 10, 2010 | HP Pavilion dv2000t Notebook
Sony laptop,PCG-K15:I have a good picture up until the windows xp splash screen then it goes black,also I can get into setup & can see everything just great.Any ideas ''HELP''
try to boot up on safe mode. If successful, you may the wrong video card settings or driver. Unistall ALL video drivers and re-set the screen resolution and colors to 800 x 400 and 16 million respectively. then, restart and let boot normally
Mar 13, 2010 | Computers & Internet
Have blank screen with box in middle Analog out of range 62.9kHz / 120Hz
whatever you are trying to attach to the tv is set to the wrong frequency. If it is a computer you need to change the video settings by attaching a known working monitor and selecting another resolution. You will have to keep trying if the new resolution doesnt work. trial and error is your only option here. it will work when you have a system that displays within that frequency and in a supported resolution.
GOOD LUCK AND PLS RATE THIS POST!!
Feb 21, 2010 | LG L1780U (Black, Silver) 17" LCD Monitor
My computer begins to load windows, then after the screen with the windows logo and bars goes away my screen goes black.
Nine times out of ten if that's when your display stops, it's simply because your display settings are set to something that your monitor can't handle. Depending on what it's not supporting, some monitors respond by going black ... others just go "crazy" displaying unintelligible gibberish.
If that's the problem, it's fairly easy to fix.
First things first ... let's get you a bootable system.
Boot in safe mode - press F8 when the Windows loader presents you with the 30 second list of choices, and then select "Safe Mode" as your boot option.
Right click on the desktop and click Properties, and then on the Settings tab.
Now click and drag the Screen Resolution slider to the far left ... you want the smallest settings that your screen will support. Typically that'll be 640x480, or 800x600.
Also change the Color Quality dropdown to 256 colors, or whatever is lowest. (You probably don't need to go as low as 16 colors, if that's presented as an option.)
Now, click on the Advanced button, and then the Monitor tab of the resulting dialog box. Change the Screen refresh rate to 60 Hertz.
OK your way back out, and reboot your machine. If these setting were the source of the problem, it should now be able to boot normally. You may not like the screen settings, but at least you now have a place to start.
"Start experimenting with the settings to see what does, and does not, work with your monitor."
If the display is still blank or gibberish, the my recommendation is to once again boot into Safe Mode, possibly Safe Mode with networking, and update your video display drivers. It's likely that they are incorrect or otherwise broken. Now start experimenting with the settings to see what does, and does not, work with your monitor.
I tend to start with the screen resolution. Once again right click on the desktop and click Properties, then Settings, and then drag the Screen Resolution slider a notch or two to the right to increase your display resolution. Now click Apply. It should change the resolution and display a small message box asking if you want to accept this setting. If you don't respond within some time, it assumes you can't see it, so it resets to the previous setting. If the screen goes blank or you can't read it, wait at least one minute before doing anything. The problem may resolve itself, and you'll be able to say "well, that resolution doesn't work", and move on to try another.
If, after a full minute or more the screen remains blank or unreadable, you'll have to reboot into safe mode, as we did originally, to restore your setting. (Why might this happen? Windows "remembers" and doesn't bother to ask you if you reset to something that you previously said worked. If you mistakenly said "this works" when it didn't ... perhaps by random keyboarding while the display was blank ... well, that could be how we got here in the first place.) You can repeat this process of trial and error for each of the screen resolution, the color depth and the screen refresh rate. (For CRT displays, you really do want the refresh rate to be as high as your monitor supports.)
Nov 28, 2009 | Dell Latitude D800 Notebook
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Veo Stingray Logo
154 people viewed this question
Top Veo Computers & Internet Experts
micky dee
meli novacole
Level 1 Expert
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
