Question about Brother SX-4000 Typewriter
Print head and ribbon do not in sync
When I type, the typewirter hammer hit the daisy wheel head correctly but it did not hit the ink ribbon for print (so the output is all blank). The typewriter had been dropped to the carpet once (from a 2 feet high table). What might be the problem to cause that? Is this something can be fixed easily?
    Problem Solver:
  • 20 Answers
Sounds like the ribbon carriage is out of position, try holding the shift, and code keys, then power up, if thats no help the hold frame might have to be resitted.
Posted on May 01, 2007
SOURCE:
The nakajima ae610 types two vertical lines instead of letters
The print hammer is striking between the letters. Two thing
you may have a petal, letter broken off. If its the same letter every time usually thats it, need new daisy wheel.
Or Homing is off when the wheel turns hammer hits between letters. Needs repair.
Or
Daisy wheel petals are bent.
Dec 12, 2016 | Nakajima Office Equipment & Supplies
How do I insert the daisy wheel on my Swintec 2416 DM typewriter?
Remove the ribbon, then remove the daisywheel, reinsert daisywheel, replace ribbon and it should work.
Jul 01, 2014 | Swintec Office Equipment & Supplies
When power is turned on the machine acts like it is supposed to. The carrier repositions itself and the motor is heard running. However, when I type, the carriage (with the disk) moves to the right with...
its a printer right?
and it dot matrix type right?
if yes. try this
check flexible cable from main PCB to print head. if its torn. maybe the initial sensor is ok but not the data line.
replace flexible cable.
Mar 04, 2011 | Computers & Internet
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
Characters are off?
change CASSETTE DAISY WHEEL
Jul 23, 2009 | Brother SX-4000 Typewriter
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Typewriter suddenly will not print!
It's been awhile since I've worked on these.
What is the typing mechanism in here? I believe Brother was using a wheel.
Jun 19, 2008 | Brother EM-530 Typewriter
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Brother SX-4000 Typewriter Logo
176 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
