Question about Video Game Consoles & Games
Gce4000ps2 screens wont both work
Got a goodmans in car ps2 adaptor gce4000ps2.i can only get 1 screen to work at a time
2 Suggested Answers
  • 33 Answers
SOURCE: i have in car dvd
The manufacturer will have a parts division that can supply you with these.
Posted on Jun 12, 2008
  • 11 Answers
SOURCE: CD player wont play disks, showing error 1 instead
The original user manual will define the headunits error readings. It is most likely an internal mechanical failure and will need to be repaired or replaced
Posted on May 21, 2009
New ps1 mem card wont formaton ps2...
I have read that some manufacture PS1 memory cards will not work properly on the PS2. I would suggest trying another PS2 to see if it's a problem with your specific PS2. If the memory card doesn't pop up on the browser screen of another PS2, it could be defective or incompatible. If it does work on another PS2, it could be something weird going on with your memory card slot on your PS2.
Oct 09, 2009 | Sony PlayStation 2 (PS2) Console
Do we need a hdmi adaptor?
you need to go to walmart and buy the av cord for the ps3
its expensive but the ps2 cable wont work
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Ps2 wont spin any discs.
its broken bcuz u probly dropped or roughed it buy a new 1
Jul 23, 2009 | Sony PlayStation 2 (PS2) Console
May 20, 2009 | Goodmans CD / MP3 car radio GCE780MPT CD...
PS2 Won't read 1 game-game works on other PS2's
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER $50-75 CALL FELTON (870) 733-1375 OR EMAIL ME IWHYOU@YAHOO.COM
Dec 27, 2008 | Sony PlayStation 2 (PS2) Console
It wont work
try and change the settings on your ps2
on the screen that says browser and system configuration press triangle.this will take you to another screen. while Playstation Driver is highlited press triangle again. this will take you to a screen that will allow you to adjust the way in which your ps2 reads discs that are inserted. try changing the settings to fast nd smooth
also some times you just have to insert the game over and over again until it works. its kinda like breaking in a new pair of shoes
Jul 25, 2008 | Sony God of War 2
PS2 on a LCD
You will need to go to your PS2 system configuration screen and change from RGB to YPbPr component video output. The 1920ex (remember to switch source to YPbPr) will then correctly recognise the signal from PS2.
Hope this helps you. I am also a 1920ex user.
Apr 16, 2008 | Sony PlayStation 2 Slimline Console
Goodmans GPDR40 problem
I had the same problem like everybody else since 2005 . GOODMANS GPDR40 X-Pro personal Media Centre. After Initialise the screen freezes - MASS STORAGE
DIRECT PRINT.
I have suspected that was the battery at fault or something to do with the power.
Why?.Because i have managed to let the Goodmans work, but only for a long time when
connected to the main adaptor.
I use it to record Video from sky,Or to use the unit as a storage drive.
Here are the steps to regain possession of the Unit.
First discharge the unit by leaving the screen on when in direct print mode,
(Move the cursor down to access this mode, normally it does this automatically.)
Make sure the screen display stays on in order to help the discharging of the battery.
Having the screen on will not switch the unit off until the battery is flat.
To have the screen on press the top button again if the display revert to a blank screen.
Once the unit is discarged the the unit will turn itself off.
Now we can connect the power lead to the unit and start the unit once more.
It normally last a couple of hours or more,but it will stop again eventually.
My suspicion is that the battery charger control is not working right and
after a period of time, may be a year ore less, will cause this problem
to all these units.
I hope it works for you too, even if not as before.
Ciao a tutti!
You can contact me at this email address:
messinasergio@yahoo.com
Apr 10, 2008 | Goodmans GPDR40 Digital Media Player
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
