Question about Fuji FinePix S7000 Digital Camera
Fuji s7000 will do everything except take pictures ???
Hi my s7000 worked fine for 4 years now after it turns on i have full access to all the menus and features on the camera but the lcd and yhe viewfiender is just black when i look through either ....i can view the images already taken on the card but i can not take any pictures/video at all they just come out black????
Anyone with any ideas before i change my camera is it fixable or even if so would it be cost effective????
  • Ben Kremer Feb 05, 2009
    G'day, i have precisely the same problem, did you find the cause? Was it expensive to repair? Cheers
  • 52 Answers
It looks as though ur photo/image sensor has been damaged. Check out how much would it cost to get it repaired/replaced.
Posted on Jan 01, 2009
My fuji s7000 zoom has coloured wavey lines when turned on. It goes back to normal intermitantly but at the moment it is constant Ian
Hi Ian.
If the lines are reproduced in the pictures taken, then the image sensor located behind the lens is starting to fail. The problem will usually get progressively worse until you won't be able to shoot regular pictures anymore.
Call Fuji and ask about repair. You can get a quote from a third party here: Repair.
May 27, 2011 | Fuji FinePix S7000 Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
Camera (FUGI FINEPIX S7000) turns on, but no image on screen. takes picture, but there is no image. started out with distorted image on screen, cleaned autofocus lens and it worked for a while. now its...
CCD failure image sensor failure
ur camera may be on service advisory list just mail the fuji film with serial number i am pretty sure they will repair free of charge it is a manufacturing fault in some units manufactured b4 2005 u have to email them they will repair it free of charge
pls rate me FIXYA for this if u like
Mar 08, 2009 | Fuji FinePix S7000 Digital Camera
S7000 - File No. Full
If you can access the card on your PC, copy off anything you need, then reinsert the card into the camera. Go into the menu and format the card. This should make the card work with your camera again.
If the card doesn't work with the PC then you more than likely have a corrupted card, which will need to be replaced.
Mar 05, 2009 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera ''CARD ERROR''
Hi there
Try using the format options in the camera's menu.
Hope this works for you.
Thanks for using Fixya!!
Feb 06, 2009 | Fuji FinePix S7000 Digital Camera
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Dec 22, 2008 | Fuji FinePix S7000 Digital Camera
Fuji finepix s7000
Per the owner's manual:
  1. Insert a formatted media into the camera.
  2. Set "RENEW" as the FRAME NO. setting in the SET-UP menu.
  3. Start taking pictures. (the frame numbers start from "100-0001".)
  4. Set "CONT." as the FRAME NO. setting in the SET-UP menu.
Then you're done. We just did this on ours and now we're ready to go. God Bless.
Jun 05, 2008 | Fuji FinePix S7000 Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
Only getting half a picture
My 4 year old S7000 just started the same thing. I read it is the CCD. I'm taking it in today.
Feb 10, 2008 | Fuji FinePix S7000 Digital Camera
Fuji fine pix s7000 flash not working
Check to see if the flash has been set to a lower power or underexposes via a +/- setting. If not, warranty repair unless the camera has been damaged.
Sep 13, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
245 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
