Question about LG WM-2277HW Front Load Washer
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT IT DID NOT START THE SAME THING IS HAPPENING PLEASE HELPUS TO SOLVE THIS PROBLEM
  • 71 Answers
Turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Posted on Jan 01, 2009
My dishwasher isnt rinsing the dishes, leaving soap on dishes. Also doesnt seen to be draining well, leaving scum on the filter on the bottom. Tried a dishwasher cleaning agent and have tried CLR. I didnt...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jul 25, 2011 | Dishwashers
My miele dishwasher model no G643V1 is not cleaning properly. Inlet/Outlet, Salt or Rinse aid lights not red. Contents all have gritty substance at bottom. Please help!
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Apr 08, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
My dishwasher suddenly started having a white residue to cover the dishes. This white residue is also along the edges at the bottom of the door and bottom front of the interior of the disherwasher and...
Remove the bottom strainers plates and make sure that the outlet pipe the pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 29, 2011 | GE Dishwashers
After dishwaher cycle complted water still remains
There is possibly a partial blockage in the outlet, preventing the water from draining out in the preset time. Remove the bottom strainers plates and make sure that there is nothing obstructing the outlet pipe and the pump or the selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 26, 2011 | Dishwashers
Water not draining from tub
Remove the bottom strainers plates and make sure that there is nothing obstructing the outlet pipe and the pump or the selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it.
Mar 20, 2011 | Kenmore Dishwashers
Dishwasher not draining last of water out
Mar 14, 2011 | Gaggenau Dishwashers
Water doesn not drain out
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again. Also check that the drain pipe is not kinked or caught somewhere.
Feb 17, 2011 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Water did not drain completely and there's quite a fair amount of water left at the bottom. The model (Jenn-Air JDB7910AWW). This was the first time that any problem has occurred. Also the lights, for...
Feb 04, 2011 | Jenn-Air Dishwashers
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
Jun 01, 2008 | AEG Lavamat 88840 Front Load Washer
LG WM-2277HW Front Load Washer Logo
206 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
