Question about GE JASRM24912 Remote Control
Need 3 digit code for Magnasonic dvd player
Have a Magnasonic dvd player model: DVD816B. I'm trying to configure my Cable Remote control so it can detect the DVD player but it doesn't detect it. I can manually put up the 3 digits myself.
Thanks in advance for your help
5 Suggested Answers
SOURCE: TOSHIBA dvd player SD-1800
curtis mathes tv codes
Posted on Dec 31, 2007
AvioriX
  • 689 Answers
SOURCE: need dvd player codes
Hi
Here is the link for all Codes
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
and the Manual for instructions
http://www.remotecodelist.com/remotes/ge/RM24912_instructions.pdf
Good Luck
Posted on Jan 18, 2008
  • 78 Answers
SOURCE: GE Universal Remote Code for my Insignia DVD Player NS-DVD1
if you have already tried "code search" then you may have to return that remote and get a different name brand of universal remote.
Posted on May 30, 2008
SOURCE: URC of NTL/UPC in ireland
Originally Posted by NTL To over come this the DVR remote can be tuned to set the volume through the STB instead of the TV set
You can set this up using the following 'quick guide'. Please be advised that you don't see anything happen on TV or the STB while you're doing this
- Press the UPC button. The UPC button will illuminate once.
- Press RED and OK together until the UPC button flashes twice
- Enter code: 993 (after the last digit the UPC button flashes twice again)
- Press the volume up button (the UPC button flashes four times)
- When this is done, the remote control won't send IR-command's to the TV set but only to the STB, including volume and mute
Posted on Jul 14, 2008
  • 686 Answers
SOURCE: need code for memorex dvd player to program emerson jumbo univers
0446 1050 1118 1123
Posted on Feb 18, 2009
I need the 3 digit code for ge universal remote model RC24912-A for sony dvd player
Code lists and manuals for GE remotes are available from http://www.jascoproducts.com/support/universal-remote-codes.asp . The 3-digit code list is here: http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit.pdf . The Sony DVD player codes to try are 166, 320, 321, 322, 361, 389, 399, 909 . (Sony DVD recorders may use 302, 321, 322.)
However, the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a newer universal remote.
I hope this helps.
Jul 24, 2011 | Universal Remote Control GE174Universal...
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Hello. I have a model # URC-4640Boo and am trying to set it up to work an a Sony dvd-vcr combo model # SLV-D300P and can't seem to find out how. Can you help me?
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Jul 17, 2010 | One For All URC-4605 Remote Control
Code for DVD Magnasonic
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Magnasonic DVD players in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes.
Therefore, I recommend using the URC-3021 Code Search feature to find the compatible codes to control your device.
Please refer to my posted Fixya Tip One For All URC-3021 Code Search, or any of the Tips posted below.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Mar 03, 2010 | One For All URC-3021 Remote Control
How to get RCA UniRemote to work Magnasonic DVD player
gave up; believe my DVD is non-compatible to remote use. period.
Nov 01, 2009 | RCA Universal Remote Control
I need a code for a sony remote for a maganasonic dvd player
You did not specify if is tv, dvd, vcr
try:
SONY DVD PAYER: 0533, 1533, 0864, 1033.
SONY DVD PLAYER/VCR COMBO: 0864.
SONY TV:0000, 1100, 0810
SONY TV/VCR COMBOS: 0000, 1232
MAGNASONIC TV/VCR COMBO: 1278
MAGNASONIC VCR:1278
SONY VCR: 0035, 0032, 0033, 0000, 1232, 0636
Jan 26, 2009 | One For All URC-4330 Remote Control
I need the code for a Magnasonic VCR DVD Combo. Model:DVD833-2
Magnasonic 0278
http://www.oneforall-na.com/set_up_remote.php
Nov 16, 2008 | One For All URC4220 Remote Control
Magnasonic mctv1311 remote control code
Go to remotefinder.rca.com/default.aspx?site=rca for the correct codes (there may be more than one for each remote and try them till you find the right one).
Oct 22, 2008 | RCA Universal Remote Control
Code for remote
Hi rmattie
Can you tell me the exact model of the remote. You have not mentioned it in your request
regards
robotek
Jul 15, 2008 | Televison & Video
GE JASRM24912 Remote Control Logo
61 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
