Question about TallyGenicom 2348 24WIRE 480CPS Draft 136 Col Serial/parallel Matrix Printer
Bad print out
Cant read some line very dark and some line very light priner tally genicom 2348
    Novelist:
  • 169 Answers
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Posted on Sep 21, 2009
Why can't I print through a Tally T5040 printer?
Tally genicom 5040 passbook printerre download the drivers and make sure you have a good connection (USB )
Mar 21, 2012 | Office Equipment & Supplies
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
I have printer genicom 4440 xt and have not a driver i want a diver for this printer thank you
Just try using a generic print driver in windows. This driver will send standard ASCII code and the printr should allow you to print standard text. try it.
Apr 10, 2010 | Tally Genicom 4440 Printer
Genicom 4440 is 15 years old and is used to print invoices with bar codes. The bar codes are not passing USPS regs. They are curved and were not like that years ago. Can the print head be cleaned or...
Yes to both questions. This printer has 3 print modules. you can try swapping the right side for the left side module or vise versa and see if the problem changes. if it does then you should replace the bad module.
Jan 31, 2010 | Tally Genicom 4440 Printer
My print out cat read some line very light and some line very dark priner is tally genicom 2348
I would recomend the following;
  1. Check the ribbon is seated correctly in the printer
  2. Check the ribbon is not jammed or tight to move
  3. Check the print head gap, ensure this is not trapping the ribbon
  4. Change the ribbon for a new one
  5. Check the ribbon drive is ok
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
Paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
Telly genicom printers
What do you mean picking papers. Do you mean feeding the paper, or printing with certain types of paper?
Aug 09, 2007 | Tally Matrix T2280 Printer
TallyGenicom 2348 24WIRE 480CPS Draft 136 Col Serial/parallel Matrix Printer Logo
132 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
