Question about Sony KV-32S45 32" TV
Vertical fold over
Sony kv-32s45 tv has thin horiz line across the center of set...sound ok...can anyone help solve this problem. i have some tv work under my belt ... thanks
  • 68 Answers
If the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
Posted on May 03, 2007
    New Friend:
Sony kv-j14L1 TV,
1. AV,sound & video OK (no color)
2. TV no sound & viedo
Posted on Jun 05, 2014
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
My screen close down from top to bottom and lives a horizontal line rite @ the center of the screen,,,,, Which component is mostly faulty in here ? and what kind a component is this ..?
Hello
It may be due to an Integrated Circuit [IC] fault. Your TV has lost its vertical sweep, and the is why you see a norizontal bright line across the center of the screen. All TVs has bot Hotizontal and Vertical Sweep to spread picture on the screen. When Vertical sweep fails, you will see a horizontal line, and when horizontal sweep fails you will see a vertical line at the middle of the screen.
n your TV, most likley the vertical Ic is faulty. This is a common phenomena in almopst all telivisions. The said IC is diretly soldered into the circuit board inside your TV. To replace it you have to open your TV. Take all precautions before opening the back cover of your TV. You are going to work with an electrical equipment, and keep it in mind always. After opening the back cover, just locate where the Vertical Output Ic is. It will be normally screwed to a heatsink plate, inorder to radiate heat from it while working. You can locate it by the following method. Different TV circuits has different positions to this Ic. Just look on the Deflection Yoke [the coil fitted on the neck of picture tube]. From there four wires will go to the main printed circuit board. Out of which two of them will be thick, and other two will be thin. The two thin wires are the carriers of vertical sweep from main board to deflection yoke. Follow the the two thin wires. You will see it to be pluged into one point at the printed circuit board. Just upside down the printed circuit board, after pulling it outwards, not disturbing any of the wirings, and look through the circuit track, to which point the tracks goes to. Somewhere near to it you can locate the above said IC.
Just take the main input votage to that IC. It will be normally 18v to 35VDC. You must have multimeter to measure this voltage. If the voltage is there, look for any loose solderings over there to the legs of that IC. If there is any soldering loose, the IC will not work properly, and vertical sweep loss will be the result. If there is proper voltage check the voltage at the output pin of that Ic. It should be almost half the voltage of the supply voltage. If it is not there, make sure that the IC has damaged.
Resolder it out from the board, and go for a same type and number. Replacing it will solve the problem. Normally vertical output ICs are not very cosltly. Here in India, all types of vertical Ics will have a price rate between 80 to150 Indian rupees, that is upto four American Dollars. Ok.
Nov 06, 2010 | Sony KV-35S65 35" TV
My television has no picture just one thin line in the center. Does anyone have any suggestions as to what is wrong?
You have a problem in vertical deviation in your television.It's need to be repaired by specialist.
Sep 28, 2009 | Symphonic ST419E TV
I have a Sony Trintron also - similar model to the
looks like a horiz.output transistor is shorted.check it...
Jul 08, 2009 | Sony KV-32S45 32" TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27FS200 bright horizontal line problem
try to replace all filter capacitor on vertical section area that can solve your problem.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Have sound but no picture
some time it works mean the tv having dry joint ( loose connection ) inside the PCB pls resolder all parts spacialy system control IC horizontal/ vertical section and power supply board as well . I think no any other issue in this tv pls resolder all part as much as possible
Jan 08, 2009 | Sony KV-32S45 32" TV
Thin white line across center of screen Fisher PC-32S90
yes there's a lose connection of your tv. It needs to re solder.if you know how to solder .,solder the vertical section specially the vertical I but be careful of short circuite coz it may damage your tv set.
Nov 16, 2008 | Fisher PC-32S90 TV
No power Up , No Sound , No picture
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Nov 22, 2007 | Sony KV-32S45 32" TV
Sony KV-32S45 32" TV Logo
174 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
