Question about Brother HL 5140 Laser Printer
HL-5140 paper jam
I have the same problem as you have posted. Got any solutions?
  • jtbooze Mar 06, 2009
    My paper jammed on top at the feeder area, and I can't get the paper out. It had previously jammed by the toner cartridge, but that seems to be o.k. now. When that jam was cleared, printer just started printing endless blank sheets, then stuck at feeder.
    JTbooze, Miami, Fl.
  • 10 Answers
Perhaps look along the paper path for the little bit of paper that maybe stuck along the path somewhere. I had this problem and it was just a little piece of the corner of a page wedged in the back of the toner tray.
Posted on Apr 21, 2009
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
Our HL 5140 won't print. The status light and paper light is flash, yet there is paper in the tray.
Hello ,
Please follow the below steps to try and clear this message.
  1. Turn the power off on the unit.
  2. Open the front and back cover of the unit.
  3. Remove the drum and toner cartridge from the unit.
  4. Check thoroughly inside for any paper jams or any other foreign objects and remove them.
  5. Reinsert the drum and toner and close the front and back cover.
  6. Turn the unit back on.
This should clear the error message on the display screen and allow you to resume normal use of the printer.
Thank you,
Pat
Mar 26, 2010 | Brother HL 5140 Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
HL-5140 model. the paper light is flashing and
Hi Patricia,
Try to do a factory reset on the server.
Whilst the printer is turned off, press and hold the GO button as you plug the printer on to the socket. Notice that all lights on the printer will turn on as well. Continue pressing the go button until the light for the toner goes up and once its up, release the button. Next, hold down the Go button again until the "Yellow Status" light turns on once on, release the Go button. Wait for the printer to initialize and see if the error went away.
Hope this helps.
Jan 05, 2010 | Brother HL 5140 Laser Printer
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
I have a paper jam in my printer but can not find my manual on how to get to the paper. Can you help me?
Manual here >
http://welcome.solutions.brother.com/bsc/public/as/au/en/doc/manual_index.html?reg=as&c=au&lang=en&prod=hl5140_all&type2=-1&flang=all&dlid=
Jun 10, 2009 | Brother HL 5140 Laser Printer
My HL-5140 paper is not coming out after printing.
Hi there
HAve you seen a small coil spring with 2 lugs come out of the machine? If you look inside the printer cavity you should see one of these springs either side of the internal black frame work.aboutThese should be about 1 1/2" into the machine just close to a clear lens on either side. If one of these is missng the drum/cartridge unit is not properly aligned and will cause jamming as you have described.
Failing that you have either a sensor problem or a faulty drum unit.
Please let me know and I'll try yo help further.
Cheers
ivorpits
Dec 30, 2008 | Brother HL 5140 Laser Printer
Brother HL-5140 printer
make sure you have the drum seated all the way in, then unplug the printer and plug it back in.
Feb 20, 2008 | Brother HL 5140 Laser Printer
Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Jan 22, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
