So the mechanic wasnt the nicest guy and didnt explain anything. I need to know how to fix this problem. I have the diagrams and everything but they mean nothing to me. i dont understand them.
I dont know what an "ECM" is and I dont know what the
"electric control valve"(ECV) is either.and "electric switching valve"(ESV) can someone help me please?
P.S. I want to work on the car myself, so easy to understand diagrams or explainations of where the parts are and what they look like would really help.
Thanks
It sounds like you really would like to start repairng cars, and maybe take up being a mechanic for a living....
Check into your local Techincal College for classes..and some high schools that still offer tech classes for cars will teach the students using your car...you pay for the parts..they get the knowlwedge/education, and everybody wins.
Good luck, and Happy New Year
Your car uses first generation diagonstics. Very simple, basic, and easy to understand.
Also very easy to repair.
The code "E49" does not exist.
I don't need the actual code to tell you how to fix your car.
Just give me a:
VERY DETAILED
explanation of the problem.
If you really want to fix this problem yourslf then you will need to go to this site http://alldatadiy.com/ and buy a subscription for your car. It cost under 30.00 and is good for 1 year. They have test procedures, repair procedures, component locations, wiring diagrams etc, everything you will need. It is well worth the money. I looked up code E49 and there is no such code. Do you know how ot pull up the trouble codes. Scan it again and tell me the correct code so I can help you.
what kind of car do you have? do you know what codes you are throwing?...the ECM is basically the computer of your car and it monitora all the various sensors....when a sensor is malfunctioning it sends a signal to the ecm...hence a check engine light...
The Engine Control Unit or ECU is a designated computer that was developed to manage the engine control system. The ECM consists of electronics which are mounted on multi-layer circuit board
. The ECM monitors and adjusts the air/fuel mixture and utilizes a catalytic converter to minimize amount of pollution produced from the engine. herses a few links to get you to at least understand what the components are...if i had more info i can help further:)
thanks for the question hope to hear back from you..
http://www.freescale.com/webapp/sps/site...
http://www.autoshop101.com/forms/h20.pdf
