Question about HP Digital Projector Vp6110 Multimedia Projector
My digital projector always do the 'rgb searching'
My hp vp6110 always do the 'rgb searching' after 20 minutes, and sometimes it's blinking, and it's very hot. any clue? thanks
  • Anonymous Mar 06, 2009
    bluescreen whwn connecting til pc with ATI and vista
  • 40 Answers
Make sure that the cooling fan is running well even after power off..keeping the device cool is the outmost important factor...sounds like it is seriously overheating.
Posted on May 01, 2007
How do I change from black and white to color
input source :Computer RGB (Digital) and RGB(Analog)
you should select the RGB(Analog)
Video ,select Auto
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 22, 2014 | Sanyo PLC XU35 Multimedia Projector
Sony VPL BW5 projector has yellow spots showing screen.
On a LCD PJ there is usually 6 polarizers. 3 IN Polarizers (one for each color...RGB) and 3 OUT Polarizers (again, one for each color...RGB). The blue polarizer that usually goes bad is the BLUE IN Polarizer.
It is usually a fifteen minute or job to replace the polarizer.
May 05, 2011 | Sony VPLBW5 LCD Projector
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
Why is the projector looking for a signal?
Need input signal from Computer or DVD player. You will have to select RGB or Video in the projector menu.
Aug 07, 2010 | HP Digital Projector sb21 Multimedia...
I've connected my laptop to the projector. It displays the image for a second and then displays 'Analog RGB searching'
Try setting the projector to VGA instead of RGB input if you can, you should be able to toggle though input modes.
Make sure that the resolution of the laptop is equal or lower to that of the projector.
Jan 28, 2010 | HP Digital Projector Vp6120 Multimedia...
Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
Apr 07, 2009 | Elmo Projectors ELMO VISUAL PRESENTER,...
BLINKING TEMP LIGHT ON HP VP6110 PROJECTOR
All projectors are cooled by the use of a fan. The light chamber has its owned fan to extract the excessive heat generated by lamp. Check to see if this fan, close to the fan is operating.
Mar 23, 2009 | HP Digital Projector Vp6110 Multimedia...
Projector
The sound came from the switching power supply and the lamp ballast circuitary. You need to replace the color wheel sensor, I can fix it.
Jan 18, 2009 | HP VP6310 Multimedia Projector
Pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Feb 28, 2008 | NEC MultiSync VT540 Multimedia Projector
HP Digital Projector Vp6110 Multimedia Projector Logo
339 people viewed this question
Clive
Clive
