Question about Brother HL 5140 Laser Printer
My HL-5140 paper is not coming out after printing.
Paper jam during printing. sheet is not coming out. it is printing only more than half the page.After every trial I have to open and remove the toner catridge for removing the paper.
    Problem Solver:
  • 5 Answers
Hi there
HAve you seen a small coil spring with 2 lugs come out of the machine? If you look inside the printer cavity you should see one of these springs either side of the internal black frame work.aboutThese should be about 1 1/2" into the machine just close to a clear lens on either side. If one of these is missng the drum/cartridge unit is not properly aligned and will cause jamming as you have described.
Failing that you have either a sensor problem or a faulty drum unit.
Please let me know and I'll try yo help further.
Cheers
ivorpits
Posted on Dec 31, 2008
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
My Brother HL-5740 Is jamming after every print jog. It's pulling two sheets through, the first sheet with the print job and the second sheet clear, Its like every job has two sheets. The second sheet...
You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
Oct 16, 2017 | Brother HL 5140 Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
HL-5140 model. the paper light is flashing and
Hi Patricia,
Try to do a factory reset on the server.
Whilst the printer is turned off, press and hold the GO button as you plug the printer on to the socket. Notice that all lights on the printer will turn on as well. Continue pressing the go button until the light for the toner goes up and once its up, release the button. Next, hold down the Go button again until the "Yellow Status" light turns on once on, release the Go button. Wait for the printer to initialize and see if the error went away.
Hope this helps.
Jan 05, 2010 | Brother HL 5140 Laser Printer
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
Printer wont print, paper light comes on, there is paper in tray
Reset the printer with the following method that I searched on the Brother solutions website - took an hour of searching...
  1. Turn the printer off.
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
Mar 30, 2009 | Brother HL 5140 Laser Printer
Brother HL-5140 printer
make sure you have the drum seated all the way in, then unplug the printer and plug it back in.
Feb 20, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
199 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
