Question about D-Link DES 3226 (DES-3226) 24x10/100 Mbps Networking Switch
My switch got burnt due to short circuit. Is there any chances of its repairing if yes then give me the address of the service centre or at what cost can i get the new one also give me the suggestion of other model.
    Problem Solver:
  • 9 Answers
I recommend replacing the switch as well. Sometimes you can get those switches to limp along for a while longer, but they can also cause additional damage to the network attached devices as well down the road.
Don't take the chance, and replace the whole thing. I wouldn't say that Cisco is the only brand that i would recommend. 3COM and others still make quality switches. Also, your replacement dependson your needs as well, as some people need managed switches and others do not.
Honestly, if what you had before worked well, I would replace it with the same thing. Additionally, make sure you're using a UPS device on this as well to prevent surge damage.
Also, as a side note. When this device shorted out, were there devices connected to it or was everything unplugged? If there were other devices connected, they too can be damages, although they don't always show signs of damage at first. Be sure to check them out as soon as you get the new switch installed and connected.
Ryan
Posted on Dec 31, 2008
    Problem Solver:
  • 12 Answers
Where is the short circuit? usually you cant fix a short unless it is in the power switch itself.i would sugest trashing it and replacing it. i always stick with cisco brand but there are other god ones. check pc world and cnet reviews on switches and routers. cost you more to repair than replace.
Television switches off by itself.
There is some kind of short circuit to any of the component/s at its circuit board. Short-circuit protection circuit [built in] energizes and shuts off the TV each time you switch it ON. The fault location to this kind of trouble is a skilled work and not a user repairable one. It is best to contact any service technician. Its main power supply regulator section circuit should be troubleshooted. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
google.com/+GopakumarGopalan
Dec 02, 2013 | Televison & Video
JVC rx 817vtn
From experience, a protection circuit has cut in, most likely due to a short in one of the DC output voltage rails on the PSU, thus giving the result of red standby LED, then green, then back to red. If the standby LED is not flashing/blinking, chances are you won't see any error codes.
This unit consists of several surface-mounted components, transistors, diodes, capacitors and resistors (many of which are miniature and often glued to the PCB) - this could become very costly, just in replacing modules as opposed to individual parts and spending hours fault-tracing looking for the problem which could cost a lot more in terms of labour.
I would recommend that you get a second opinion - take it to a service centre, obtain a quote for the estimated cost of repair (and fault diagnosis at the same time) - then you can make a decision after that.
It's up to you but before spending ANY money on it, throwing it out, or selling it somewhere as is, or whatever, get that second opinion from an authorized service workshop first. See how you go. *Nothing is impossible to fix, some things are complex.*
Aug 24, 2013 | JVC Audio Players & Recorders
My player is samsung p380. it is not working. only the powerlight(red light)is glowing. can you suggest a solution
Does the unit operate with the remote? If not, then there is a good chance the switchmode power supply is faulty, mostly due to a short-circuit, hence the standby LED being the only sign of life.
It is either a protection circuit which is active, preventing the unit from operating, or simply no regulated output from the PSU.
Usually IC regulators in the PSU short-circuit, or suffer partial failures, resulting in the aforementioned symptoms. Electrolytic capacitors also cause major problems in this area. The trouble is, if you submit the player to a service centre/repair shop, it could be expensive and/or uneconomical, as the unit is not a DVD recorder, and you have to remember a workshop charges labour per hour on top of any part(s) they use. You can obtain a quote on the likely repair/part(s) cost(s), then make a decision afterwards as to whether it's worth going ahead or not. It is up to you.
As I have mentioned in previous postings, Samsung have a habit of using unusual rated/obscure valued ('specialised') components in their switchmode power supplies, making these very difficult to repair without some modification. Some of those components are not available to the public off the shelf, so this has to be done by a qualified technician in a fully equipped authorised appliance service workshop.
If you find that it is likely to cost you more than the retail price of a brand new unit, cancel the repair of this and buy a new one - but ONLY as a last resort when all else fails. New players are cheaper to buy (even Blu-Ray), while repairs on existing models become more expensive and parts become more difficult to obtain.
Mar 24, 2011 | Samsung DVD-P345 DVD Player
The DVD Recorder just doesn't power up..
No power, display or functions at all? It is likely that one or more components in the power supply are short-circuit, leaky and/or open-circuit. The trouble with switchmode power supplies is usually caused by (but not limited to) electrolytic capacitors - these fail in all sorts of ways including leaking or drying out due to their proximity to parts with heatsinks, such as IC regulators. The cost of repair depends on which service centre you take the recorder to, who you deal with, and the combined replacement parts/labour involved.
If you are prepared to spend a small fortune in getting this unit fixed, go ahead, get a quote for the likely repair cost FIRST; then you can make a decision afterwards based on the information from the repair shop as to whether this is economical to repair or not. You may or may not be charged a fee for the quote on repairs.
It is up to you. If you feel it might not be economical or cost-effective to fix this one, get the second opinion from the service centre first, then maybe later on consider a new machine if nothing else.
These days, products become cheaper to buy, but more expensive to repair.
Mar 03, 2011 | Pioneer DVR-520H DVD Recorder
My UPS burnt due to short circuit in main line. After that the UPS don't give back-up even for second. After recharging the battery and connected to the UPS, the UPS don't give power at the output from...
if there was a short circuit, chances are that its toast. get a new one. DON'T ATTEMPT TO OPEN IT YOURSELF. THESE THINGS STORE POWER SO YOU CAN BE ELECTROCUTED EVEN IF YOU UNPLUG IT.
Feb 02, 2011 | Computers & Internet
I have Videocon Plasma Model, problem in plasma Panel y board panel r as per the videocon servicing centre. Part detailos are- yd 07 Samsung panel? Should i replace it or think for new TV? What will be...
IF YOUR Y BOARD IS SHORT YOU WILL HAVE TO REPLACE THE TWO Y BUFFERS THIS WILL COST TO MUCH THE EQUIVELENT OF YOUR TV IS 430 WITCH COST ABOUT 600 DOLLARD
Nov 17, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Tv is pluged in, but will not turn on
If the TV shows absolutely NO sign of ANY life when turned on at the front on/off switch, chances are the switchmode power supply has a short-circuit or is blown due to a surge; it wouldn't just be a fuse. Many parts could be affected and would need to be replaced here.
If you have no standby LED on the front at all, the first line of attack would be the SMPS, and progress from there.
Very complex to those unfamiliar with circuits like these, and could be uneconomical to repair.
If you have doubts, take it to an authorised service centre, and get a FREE quote for the likely cost of repairs, parts/labour etc., then make a decision afterwards as to whether or not you want to pursue it.
If the fault is confined to the power supply, this may not be so expensive to repair as opposed to the line output or vertical stages, but get the free quote from a service agent first.
Jul 11, 2010 | Panasonic CT-36HX42 36" TV
Sony ericsson w595 has a problem.The motherboard is shorted due to charging faults,the charging section of the board is completely burnt & black.can't identify the components.What can I do?
its a short circuit and hard ware problem you have contact any cell phone service centre or try toi contact sony ericsson ok it could be costly
Jan 12, 2010 | Sony Cell Phones
Push power on button; lites up then goes off
there may be many reason behind this, according to you, its switching circuit is ok. but when u switch it on ,the voltage goes to different circuits but due to short circuit between there path. it giving shut down signal so its shutting down imediatelly. basically this the fault of sort circuit. this may happen due to core voltage short(maximum chances), gmch controllar, south bridge(very less chance). u may try.hope this may helpfull for u to identify ur problems.
Aug 23, 2009 | HP Pavilion dv1000 Notebook
Disney mcqueen tv DTP1363-CAR
yes it can be repaired for sure .it will cost you near to between  $10 to $ 150 plus the service charge of the technician. as sometimews this causes due to very minute short circuit and a small ic or capacitors gets blown and the cost for that 1 single capacitor is very negligible so it can be $10 also. thanks.
Jan 05, 2009 | Disney DTD1363-CAR 13" TV/DVD
D-Link DES 3226 (DES-3226) 24x10/100 Mbps Networking Switch Logo
220 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
