Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
I put the micro hc 4gig sd in the adapter, but my usb card reader does not recognise it, and also my toshiba laptop sd slot reader does not read it either, all my other normal sd cards work fine, and they are up to 2 gig sd cards, I purchased this 4gig micro,hc card for my mobile Phone, any help would be much appreciated I just got it and When i slide it in to the adapter and plug it all in, it takes about 5 minutes to load and then when i double click on my drive it says "please insert drive to slot i''.
my 128m one works fine but this one doesn't
    Problem Solver:
  • 18 Answers
Your device is probably not compatible with the more recent SDHC (High Capacity) memory card format. Newer equipment can handle both SDHC and SD. Check with the manual or website for your card reader and the laptop, to check if they can recognize it. None of our older cameras can use SDHC, but it works fine in my daughter's new Pentax.
Posted on Dec 31, 2008
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
Where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
I bought an 4gig SD (HC)? card for my Camera. On start up, the Camera reads "FORMAT SET:OK" but when I select OK it Says CARD ERROR!. I've traded the "defective" one in for a...
The A402 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jan 15, 2011 | Samsung Digimax A402 Digital Camera
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
Micro sdhc card reader will not recognize 8gig card
You problem is most likely to be the fact that your micro chip is a HC chip. HC chips have a new program that is not backwards compatible to regular sd host ports. This is a simple fix, however. If you don't trust downloading programs for it on the internet, just go to target or walmart and get a USB SD card reader, and a SD adapter if you don't already have one. The usb adapter should only be like $10 at most.
Jun 07, 2009 | SanDisk 4GB microSD High Capacity Memory...
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
Does the micro sd card been detected by your computer? If not, you may try other card reader, or other computer. If still does not detected, you may try to go to device manager and see whether the sd card is there, if yes, then you can assign a drive letter to the sd card.
Once SD card shows as a drive letter on PC, you can download sd card recovery software to get back your files. recommended asoftech photo recovery that helped me before. download it from link below
SD Card Recovery Software
You can refer to this card recovery tutorial
Recover files from SD Card
If above does not work, you may have to format the memory card (use quick format), and then use Asoftech Data Recovery to scan again the memory card and recover your files.
Dec 09, 2008 | SanDisk 4GB microSD High Capacity Memory...
Sandisk 4gb microSdhc wont read in computer
few computers nowadays read SDHC out of the box. you will need to purchase a SDHC reader that plugs into your USB port.
May 12, 2008 | SanDisk Cruzer Micro MP3 Player
HELP w/ Sandisk 4GB MicroSDHC Memory Card with SD Adapter
First check it in ur laptop whether Card reader was installed or not.If ur laptop doesn't install drivers then Take from nearest service center and install the drivers.
Thanks
Mar 06, 2008 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
548 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
