Question about Frigidaire FEF336BC Electric Kitchen Range
I have a freestanding Frigidaire electric range that has been working fine but a little while ago I'll is using the oven and the top buners at the same time and suddenly lost complete power to everything not even my inside light will come on in the oven, I know this sounds like a circuit breaker which I check my outside to 20 breaker and he did not flip so my question is is there a breaker inside the range itself they can overload and be reset our have I killed my electric range and need to buy a new one
  • Anonymous Mar 27, 2014
    would this effect the oven from coming on
    Scholar:
  • 140 Answers
Recheck you breaker. Turn it off and then turn it back on a couple of times. There aren't any fuses in the stoves. If that doesn't work you'll want to call an electrician to check your plug and breaker. Good luck.Please rate me so I know how I'm doing. Thanks
Posted on Dec 30, 2008
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
We get F3 when we try to set the temperature on the oven. What does F3 mean?
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
No power on the disply panel
replace the control clock its shot...you may be under warranty,,check the last page in owners manuel,,,
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont work
If the sensor were bad, the unit would throw a fault code. On the back of the range, near the top, there should be a tech sheet for you to use to troubleshoot the range. It sounds like a thermal sensor may have opened up. Consult that tech sheet, it should point you in the right direction.
Dec 12, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES400 oven controls
Contacts are fused.  Get a new one, cut the power and replace it.
Nov 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
Jul 14, 2008 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire FEF336BC Electric Kitchen Range Logo
157 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
