Question about Sony FD Trinitron WEGA KV-24FS100 24" TV
No picture, no sound
When i try to turn tv on, a red light flashes, until the power button is pressed again
  • bobmagli Jul 03, 2008
    The red light flashes 4 times. Must repeatedly hit power button until picture and sound finally come on. Sony Trinitron KV-24FS100
  • Anonymous Mar 16, 2014
    my bush dv3 has suddenly gone wrong, when i turn the power on, the blue light comes on at the front, so i know there is power getting to it, but when i press the button to turn it on, the blue light on the front goes out and notthing else hppens, there is a red light flashing at the back of the tv, and if you look very very hard you can only just make out, the menu if you press that button, but not enough to see what it says, i have tried turning it off for a while, and starting again, but it does not help. is there anything i can do?
  • 68 Answers
You have a problem in the power supply section. are you a tech person? if not, I suggest that you take it to a repair shop..good luck
Posted on May 10, 2007
Loud buzzing sound from tv with no picture
It sounds as though your SMPS is seriously faulty and normally one can buy a kit to correct the problem if you are a TV engineer, however there could also be many other reason for the condition that you describe its almost impossible to guess correctly, it really needs a qualified engineer to assess the problem along with he or she having the set with them.
Sep 04, 2016 | Samsung PN42C450 42 in. TV
Sony kdl52xbr9 it comes on i can see picture and sound for a couple of seconds, then it shuts off and blinks 6 times
Hi! and Welcome to Fixya!
Blinking red lights on the tv are error codes that explains hardware issues on the tv.
However, if after turning ON the tv and you will see the Sony logo on the screen before the picture goes off and then flashes red lights for a number of times, this could mean that tv can still be recovered. Try the option below to isolate possible issue with settings that cause your tv to shut off. Disconnect first all external devices from the tv
1. Turn ON tv first and wait until it flashes the red lights > press and hold down the UP Arrow button ( use remote control ) > while holding down the UP Arrow button, press the POWER button on the tv > tv turns off, wait until it turns on by itself > release the UP Arrow button when tv turns on
Note: reset is successful when you see a welcome screen on the tv and ask you to select your Language. This is the Initial Setup, just follow the on-screen instruction
If that solution did not resolve the issue then a service may be recquired.
Let me know if this helps!
Oct 27, 2015 | Sony Bravia Kdl52xbr9 52 1080p Lcd Tv...
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Sky remote code fo LCD LE40A456 TV
3. Press tv again
Samsung Code: 0060
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
3. Press tv again
Sony Code: 0000
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Pairing Sky+ Remote with Panasonic Viera remote
3. Press tv again
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony FD Trinitron WEGA KV-24FS100 24" TV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
