Question about Sony KP-61V90 61" Rear Projection Television
A chip on the circuit board started smoking
I was watching my tv when the picture went out and i smelled smoke so i unplugged the tv and opened the back. There was a small peace on the circuit board that had started to smoke when i plugged it back on. I am not sure what that peace controls or if it is possible to replace. I cant find any breakdown on what parts are what. please help
  • 10 more comments
  • micluccha Jan 01, 2009
    I seen smoke coming from the main circuit board in the back of the televison, It looked smoke was coming from I think a fuse. it is a small black square that was attached to a metal plate. On the black piece it had 1ohm on it
    the earliest i can send a photo is Monday
    it was the board on the left. d-2578
  • micluccha Jan 02, 2009
    D2578
    where would i find the IHVT?
    how can it i test it to see if it is working correctly, I have friends who has a background in electronics. He has a voltage reader. to test it if that is all that needs to be done. If so what voltage should he look for?
  • micluccha Jan 08, 2009
    the varistor behind the resistor was fried and when taken out I could not read the number off it to order a replacement one. When looking at the skematics can you tell me what type of varistor to order.
  • micluccha Jan 09, 2009
    replaced the horizontal output transistor(D2578) and the varistor behind it. Now the power light blinks four times then goes off. Then it repeats, blinks four times goes off. The screen will not come on. What could be the problem?
  • GreyMatterSF May 11, 2010
    I don't understand what a "small peace' is. There is no such phrase in English.
  • cyriacus joseph May 11, 2010
    what part got burnt?
  • Henry McKelvey
    Henry McKelvey May 11, 2010
    If possible can you post a picture of the board and the component that was smoking? This will be a great help in seeing what is happening.
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
  • acdcsl8r
    acdcsl8r Aug 21, 2012
    ^Being a **** doesn't help, go be useless somewhere else.
    Sergeant:
    Champion:
  • 346 Answers
The part which is black and is mounted on the metal plate is the horizontal output transistor (D2578) The part which is 1ohms is a resistor In order to replace, you need to get the location number which is written on the circuit board -for example Q552 could be the location number for the transistor
To get the correct part you have to call sony the manufacturer and give them the name of the tv
the model number of the tv
and the location number of the burnt part
Please refer to a qualified tv repair personnel to do repair on tv
Posted on Jan 02, 2009
  • cyriacus joseph Jan 09, 2009
    check vertical output ic
    Genius:
  • 1,139 Answers
The component sounds like a resistor, and the fact that it was attached to a heat sink means its a power handling resistor. You said it was burning, so this means that whatever it is attached to is drawing too much current. From what you are saying a component on a board is drawing too much current and is causing another component (the 1 ohm resistor) to burn. My question is what board is this (I am suspecting the deflection or the HV power supply). Please post a picture of the board in question. That way I have a visual guide as to the board and if I can find the schematic, or if you can supply the schematic I'll be able to at least give a better diagnosis of this problem.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 01, 2009
  • 6 more comments
  • Henry McKelvey
    Henry McKelvey Jan 01, 2009
    I have the schematic on file, now what I need from you is a picture of the board and the component, post it here and send a copy to service@electron-age-technologies-llc.com.
    Thank you,
    Shuttle83
  • Henry McKelvey
    when you took the back off of the TV which board was the smoke coming from? The board on the left of the board on the right (facing the rear of the TV?
    This will let me know if it is the G board (left side) or the A board (right side).
    Send me this ASAP. It will help me locate the possible problem faster now that I found the schematic in my archives.
    Thank you,
    Shuttle83
  • Henry McKelvey
    Hello micluccha,
    can you give me the resistor number from the circuit board ( The number should be R) i.e. R587 or something like that.
    I am currently looking at the schematic and might be able to localize the problem.
    Thank you,
    Shuttle83
  • Henry McKelvey
    Henry McKelvey Jan 02, 2009
    If the HOT (Horizontal Output Transistor) is the problem, I would also suggest checking the IHVT (integrated High Voltage Transformer), since what is puzzling is that that if the HOT has shorted the the current should have also opened the IHVT since it did not the IHVT might be shorted, as cycus suggested if you do not have a background in electronics you should get a qualified TV technician to work on this set for you.
    Thank you,
    Shuttle83,
  • Henry McKelvey
    The IHVT is the biggest component on the G board. It has a large red cable coming from it. It is also referred to as the FBT (Flyback Transformer). This component should be tested and replaced if needed by a qualified TV technician, due to the voltages present on the anode of the CRTs during removal of the HV cable from the transformer.
    Thank you,
    Shuttle83
  • Henry McKelvey
    Hello micluccha,
    To test the IHVT you will need to perform what is called a ring test, if you friend has equipment to do this then it poses no problem. However, make sure your friend tests the Horizontal Output Transistor, the IHVT, and the associated circuitry.
    I hope this helps,
    Shuttle83
  • Henry McKelvey
    Henry McKelvey Jan 08, 2009
    The part number is 1-801-073-31 which is marked as a critical part so you have to replace it with an OEM part. You must contact SONY's Parts Department (go to the SONY web site and look for technical support) give the following information:
    Model Number: KP-61V90
    Board Designation: G
    Reference Number: VDR601
    Part Number: 1-801-073-31
    I hope this helps
    Thank you,
    Shuttle83
    http://www.ekectron-age-technologies-llc...
  • Henry McKelvey
    Henry McKelvey Jan 12, 2009
    Hello
    check the vertical output IC (IC1509) and or the vertical pulse buffer transistor (Q1505).
    Thank you,
    Shuttle83
I have a rca d52w23 while i was watching tv in shut off and there was like a smoke smell I mean I turn it on and it shuts off by it self is it worth fixing it and what can cause this problem
Where there is smoke something burned--unplug set for safety and if curious open rear cover and look at boards near rear of set for a burnt part--that will usually determine if worth fixing or not.
Apr 26, 2012 | RCA D52W23 52" HDTV CRT TV
Hi, LG 42" today started
you need to take rear cover off to inspect whats happened ..u will see or smell what gone wrong if done asap... UNPLUG FIRST ....
Feb 27, 2011 | LG Televison & Video
I was watching the tv, when the screen went blank but the voice was still on, then smelled something awful, like something plastic melting, then noticed a lot of smoke coming up from the back of the...
Most probably, Electrolytic condenser in the Power supply to display circuit may have punctured resulting in smoke coming out. Take tv to service centre. There is no other option.
Good luck.
Rating the solution is highly appreciated.
Mar 15, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv started to smoke took apart and found found the
I assume it was the power supply that you replaced? It is very likely that a fusible device on another board has gone open circuit to protect any damage due to the initial problem. Again I assume you have a plasma TV in which case there will probably be a problem on the Y or Z sustain boards which may also need to be replaced as this may have been the reason for the other board to burn up
Dec 20, 2009 | Televison & Video
Convergence chips changed out now I have no picture
undo what you have done now also unplug convergence circuit and see if set comes on you may have solder two pins together are one to ground
Feb 22, 2009 | Hitachi 43FDX01B TV
42" magnavox plasma started to smoke, has audio but no video?
power board replacement a burnt circuit is visible upon opening unit and removing the power board.
Jan 27, 2009 | Televison & Video
TV on, sizzling sound, smell smoke, picture goes out but TV still on
It could be any number of components on the main board/power board which could be frying..But if you are hearing a sizzling sound, it could be something probably like a capacitor or the board itself. Difficult to say unless it is opened. First thing, though, is unplug the TV from the mains as a precaution against fire.
Since you are a technical guy, it shouldn't take you long to figure out what the components are thats burning. However, if your TV is under warranty, I advise against opening up the set as that will void your warranty. However, if its not under warranty, go ahead and open up the set and see what components need replacement, or replace the whole power board itself (if you are comfortable with electronic soldering/desoldering).
Cheers!
IrishDruid
May 10, 2008 | Protron PLTV3250 32 in. LCD Television
Replacing Circuit Board Capacitor
820pf / 2KV capacitor Philips # 483512257004 Andrews
Or # 13-821U HB Electronics .......T.
Nov 08, 2007 | Philips Smart 25TS54C 25" TV
Tv WENT OUT
Picture tube failure is rare problem. Your problem is powersupply failure and short circuit in deflection area. This is quite common problem. My sugestion is before you got this problem picture clarity and color clarity is better perfomance in your satisfaction means repair is better. Otherwise replace it.
Sep 10, 2007 | RCA 24V511T 24" TV
Sony KP-61V90 61" Rear Projection Television Logo
884 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
