Question about Onkyo TX-SR505 Receiver
Onkyo TX-SR505 Hum
Should the Amp show HUM at max output. It is most noticable on DVD Play.
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Hum in Onkyo TX-SR505
Try to check the cables connectors maybe loose or cold solder this a common problem also,or buy a branded cables if it hum again.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 07, 2009
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
How to connect android movie box (Mx3) to TX-SR505 receiver
The TX-SR505 does not support Video Streaming, Thanks, JT
Dec 19, 2015 | Onkyo TX-SR505 Receiver
A friend who blind has purchase this item some time ago 2007 I believe. We have a number problems with it. 1/ There is a hum of 50 c/s from the deck (I assume from Mains Transformer) when switched on and...
initially it sounds like a ground hum Something is touching ground inside. have you had it open? Look at the out put SSR's and follow them to the out put jacks. can you replace the jacks if need be? have you tried different cables? Does it do it if you use another deck other than the Onkyo. If all looks good and you think the Onkyo is the issue you may have bad IC SSR(s). Do you have the Tech ability to replace the outputs {solid state relays}?
Let us know what conclusions you have come up with. Other wise the sad part is a $110 dollar repair bill or $189 new amp/deck.
Jun 18, 2015 | Onkyo Audio Players & Recorders
Component Audio Not working
Hello, where is the issue, audio or video? Your question has mixed messages. Thank you, Onkyo USA
Jun 02, 2017 | Onkyo TX-SR505 Receiver
I have no output from subwoofer
Hello Fixya customer,
Thank you for your question.
Please check that the sub woofer and RCA cable are working by removing the RCA wire from the Sub woofer output of the Onkyou and touching the center terminal of the RCA plug. You should here a hum when it is touched.
If you get the hum, then the next step is to "Clear" the Onkyo by holding down the "VCR and Stby" button until you see "Clear" on the display. Warning, this will clear any settings special that you have made to the receiver, but will get you back to the Factory settings.
Lastly, check various sound fields, and the Sub woofer volume setting, if you still do not get sound, please have a Onlyo service center verify the output.
Thank you using Fixya.
Apr 28, 2010 | Onkyo TX-SR606 Receiver
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
I know that this is not Cheap But, If you want this to go away you need to Upgrade the A/V Cables to Monster Cables and it will Fix this Problem!
Dec 30, 2008 | Onkyo TX-SR505 Receiver
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
Hum from speakers
I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
Dec 11, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR505 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
