Question about Frigidaire Affinity ATF7000E Front Load Washer
E10 error Hi, could you please send me more info about where to find the cold water filter. thank you so very much
  • 640 Answers
Thers no filter just inlet vavle screens....pull fill hose off and there little screens inside the water fill vavle,,always replace after cleaning..onthejob
Posted on Jan 31, 2009
HOTPOINT ULTIMA WD71..WHEN THE MACHINE IS SWITCHED ON TO A WASH PROGRAM IT WORKS FINE FILLING WITH HOT WATER THEN STARTS ITS CYCLE. WHEN THE MACHINE REACHES THE RINSE1 CYCLE IT STOPS WITH A E10 ERROR CODE....
Following is pre-typed, saves time - in your case just refer to 'cold' please ;-0)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 16, 2011 | Hotpoint Ultima WF860 Front Load Washer
My zwf1631w gets halfway through an cycle and then displays E10 error code, please help!
Zanussi (? Sorry- I don't regognise your particular machine number) E10 tends to suggest a problem with the water supply.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jun 18, 2011 | Washing Machines
Comes up 5 minutes after cycle starts, e10.
I don't see a brand listed for your washing machine. But an e10 error code can be due to a water supply issue. This is often the result of the water inlet screen being plugged, but it could be as simple as a kinked inlet hose. Check that the water supply to the washer is fully turned on and that all the hose connections are tight. Also make certain that the hoses are not kinked and are as straight as possible. Getting at the screens will probably mean disconnecting a hose and removing a cover. Once you get to the screen clean it out with a small screwdriver, toothpick, q-tip or other appropriately sized tool. Be careful when digging into the washer and always make sure the washer is unplugged when performing work.
Mar 02, 2011 | Washing Machines
Error E10
Hi
Error code e10 means Problems with water inlet or during drain cycle. To resolve the error take the cold water off the inlet tube to the washing machine. Now turn back the water back on. Also, check for filter screen at inlet valve, remove it and clean. If this doesn't work then the door is not latched properly. If this doesn't resolve the issue then you would need to replace the water valve on your machine. Hope this helps...
Please post back for any further assistance.
Daniel
Aug 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code E10 what is it
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
May 31, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidare galllery series washer when i wash sometimes it wont spin and it says E10
Hello, The E10 error code indicates there is no cold water coming into the machine, either this is because the inlet valve is bad or there is a kink in the cold water line or a blockage in the filter screen where the cold hose hooks up to the machine or one of the kids turned the cold water off at the back of the machine :) Either way you should check everything I have listed, If you can't find a blockage replace the inlet valve. If you have any questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 09, 2009 | Frigidaire GLTF2940ES Front Load Washer
E10 error code. I have to keep hitting the start
hi
it is water pump error ,,please check it thank u,,
please rate it
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Drying
The E10 error code means - not filling water.
The problem could be because of clogged filters on the water inlet line or a malfunction inlet valve.
Also there is still some water inside accumulated so please do check the filter for blockages.To avoid other errors check the outlet valve and the filter as a precaution.
Good luck with the machine.Please do rate my solution.Also do post comments for further help if needed.
Apr 11, 2009 | Washing Machines
Washing machine not starting
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2009 | Washing Machines
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
120 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
