Question about Onkyo TX-SR505 Receiver
Hum in Onkyo TX-SR505
Should the amp show hum at max output. I get it on DVD play.
  • rdegour Sep 27, 2009
    it is always there at any volume, just more noticable at higher volume. have run a common ground between all components. did not help.
  • dirk boon
    dirk boon May 11, 2010
    Does it only appear at max volume or also on a lower volume ?
    The problem could perhaps be solved by turning the net plug .. , or one of the cables could also be a problem if the cables are too cheap, they are usually bad earthed ..
  • 2,071 Answers
Try to check the cables connectors maybe loose or cold solder this a common problem also,or buy a branded cables if it hum again.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 07, 2009
    President:
  • 1,990 Answers
I know that this is not Cheap But, If you want this to go away you need to Upgrade the A/V Cables to Monster Cables and it will Fix this Problem!
Posted on Dec 31, 2008
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
How to connect android movie box (Mx3) to TX-SR505 receiver
The TX-SR505 does not support Video Streaming, Thanks, JT
Dec 19, 2015 | Onkyo TX-SR505 Receiver
A friend who blind has purchase this item some time ago 2007 I believe. We have a number problems with it. 1/ There is a hum of 50 c/s from the deck (I assume from Mains Transformer) when switched on and...
initially it sounds like a ground hum Something is touching ground inside. have you had it open? Look at the out put SSR's and follow them to the out put jacks. can you replace the jacks if need be? have you tried different cables? Does it do it if you use another deck other than the Onkyo. If all looks good and you think the Onkyo is the issue you may have bad IC SSR(s). Do you have the Tech ability to replace the outputs {solid state relays}?
Let us know what conclusions you have come up with. Other wise the sad part is a $110 dollar repair bill or $189 new amp/deck.
Jun 18, 2015 | Onkyo Audio Players & Recorders
Component Audio Not working
Hello, where is the issue, audio or video? Your question has mixed messages. Thank you, Onkyo USA
Jun 02, 2017 | Onkyo TX-SR505 Receiver
My onkyo tx-sr705 produces a humming noise out off all the speakers when no audio is played
I found the source of my hum. I have Direct TV HD. I found that going into the menu settings (Direct tv HD Receiver) /Audio/Sound Effects and turning that option off, I was able to rid myself of the annoying hum. The option has something to do with keeping the audio settings from channel to channel, while it is changing you hear dead air except for the hum. Nice and quit now. Love this receiver!
Mar 06, 2008 | Onkyo Audio Players & Recorders
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
Hum from speakers
I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
Dec 11, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR505 Receiver Logo
240 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
