Question about Oster 12-Bottle Wine Cellar - Black
Fan doesn't work on oster wine cellar
How do I get a wiring diagram for oster wine cellar model#0w0912h6h?
  • Custom Exchange
    Custom Exchange May 11, 2010
    New Friend:
The outside rear fan on my wine cellar seized and caused the unit to stop working. I replaced the fan with a close match (12vDC, 0.16amp) and the unit is working again. I also took the time to replace the in-line fuse in the upper left corner of the circuit board, just based on all of the blogs I read about it failing. I did all of this only becasue the unit was past it's warranty (>1year) I think however that the main problem with these wine cellars is that the two fans (one on outside, rear and one inside) are just too weak. They can easily be stalled if the air flow is blocked. Oster should have spent a little more money on a good fan and they might not have all of these dissappointed customers.
Posted on Mar 03, 2013
    Problem Solver:
  • 7 Answers
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Posted on Feb 23, 2009
Stopped cooling no humming or nothing digtal reading are working but nothing else
you need to replace the fan at the back of the unit. no noise means the fan is not working. The fan removes the heat from inside the unit to cool it. no fan, no cool. Your local appliance repair can fix it. the fan does not cost much and there isn't much labor involved. If you want to tackle it yourself then take your model number to the appliance store and order a fan, remove the back and replace the fan. Some fans are plug and play, some are not. if yours is not plug and play then you will have to splice wires. either way, the fan is your problem.
Nov 23, 2010 | Oster 12-Bottle Wine Cellar - Black
My wine cellar (Model: ow0912H6H) still runs but it does not cool. What can I do? I don't believe that there is a compresser in ot. I don't know what cools it.
I had the same problem and noticed that the lint screen behind the cooler was full of lint where it was almost completely clogged. I vacummed it and it seems to have done the trick.
Feb 19, 2010 | Oster 12-Bottle Wine Cellar - Black
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Taking a long time to cool down and when does the fan kick on
the evaporater fan should be opperating when the compressor is runnig ,as well as the condenser fan if you have one
May 19, 2009 | Oster 12-Bottle Wine Cellar - Black
The fan does not go on
Ther are two fuses in back panel of unit. One fuse can be seen other is hidden top left of panel and is coated in black shrink rap. I had to replace that fuse to correct the problem. Problem is I had to cut away shrink rap and resolder another fuse, you may have to have someone who can do this look at your uint. Hope this helps.
Dec 19, 2008 | Oster 12-Bottle Wine Cellar - Black
Fast start option does not work
I'm not sure how you ended up under this classification;
All Products > Oster > 12-Bottle Wine Cellar - Black > Troubleshooting
but your problem with an undescribed brand and model will not likely ever get a response.
I think your question is in regards to a microwave oven. Try reposting it with the correct brand and model #.
Nov 06, 2008 | Oster 12-Bottle Wine Cellar - Black
Broken door...
Buy a dented unit on eBay and take off the hinges
May 12, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
525 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
