Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Widescreen tv=widescreen movie still have black on top & bottom
I have a widescreen plasma why do widescreen tv=widescreen movie why do i still have a black strip on the top and the bottom of the screen?
I have an AKAI pdp4294?
  • gjnesmith Jan 02, 2009
    wide screen LCD TV with any dvd has a black band at top and bottom.
    very frustrating. why did I buy a wide screen??
    Thanks
  • bambabisly Mar 13, 2009
    i have black band top and bottom when i see a series such as heroes lost and i have widescreen, what should i do?
  • 4 Answers
Sorry, you didn't provide enougb information for anyone to accurately answer your question. The most important thing you omiited was the nature of your video source. If anyone does answer this, I assure you it will be a wild guess. Here's my wild guess:
Your HDTV has a widescreen aspect ratio of 16:9. For every 16 units of width, there are 9 units of height. That ratio matches the exact ratio used in widescreen television broadcasting. However, most feature films (movies) on DVD have an aspect ratio of 2.35:1 or even wider than that. These films will display with horizontal black bars at the top and the bottom, so that you can see the full image. Unless you choose to use one of your TV or your DVD player's options to zoom or crop the image, the bars are 'correct' and there's nothing wrong.
Another possibility is that you have not configured your video source, such as a DVD player, to 'know' that you have a widescreen TV. Nearly all DVD players ship configured to output using a NON-widescreen aspect ratio, so you must adjust this setting using your player's setup menu. The same is true for most cable boxes and satellite receivers.
Finally, just because your TV is widescreen, the video source itself may not be. Most standard-definition broadcasts are NOT widescreen, for example.
If you re-post your question with adequate information about which video source exhibits this problem, I'm sure you will get much more specific and helpful answers.
Posted on Jan 01, 2009
    Problem Solver:
  • 6 Answers
Change screen settings
Posted on Dec 31, 2008
    Problem Solver:
  • 4 Answers
The answer to your question is : if the movie or program is "letterboxed" "widescreened" or "cinama scope" you will have a band at the bottom and top exactly like the band at the bottom and top at the movie theater. A lot of movies are "pan and scan" that is it is dubbed from film to video tape by a camara that pans a square picture from the area inside the letter box so you miss parts on the right or left as it scans where the people or action is and cant scan it all or it would have a black band again at the top and bottom.
    President:
  • 1,284 Answers
One of the more common issues on older Akai plasma sets is the surface mount resistors on the ribbon cables that connect to the lower address boards. They often develop cracks in the solder rendering them basically as open thus giving a black strip. Unless you have any knowledge in electronic repairs it is best to leave this to qualifies personel to repair since those ribbon cables are very fragile and once broken will require the replacement of the plasma panel itself.
Netflix has 25 percent black screen at the top!!!
Your screen resolution is incorrect for the resolution of the Netflix stream, try changing the size settings on your TV. (If your TV is not a modern flat screen it will be over scanned )
May 12, 2014 | Netflix
Black bars on top and bottom when watching movies on plasma will it hurt tv
Your refering to the widescreen cinema mode.This will not affect plasma.Only still pictures with colour retention will do it but even then it would take many hours to take effect if at all.
Jan 01, 2010 | Pioneer PDP-6020FD 60 in. Plasma TV
The picture is crunched like if you were watching a letterbox movie.(with the black at the top an bottom of the screen how do i correct this
Black on top of bottom is widescreen.. Some dvd's are made in only widescreen. Usually you have to buy a full screen disc to cover the entire screen or change to format to 16:9 or 6:9 or whatever it handles/
You may see the black on top and bottom, it is annoying at first, but the picture is so much wider and you can actually see more on a widescreen
Dec 01, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
DVD WS does not display right on Samsung 40'' HD 1080P LCD TV
Check the aspect ratio of your widescreen DVD. I'll assume that your flat panel TV is widescreen, which would mean it has a ratio of 16:9. Some movies are even wider than that (i.e. 2.35:1), so it would be normal for you to see black bars at the top and bottom. Look for a WS DVD described as 16:9 (usually shown on bottom on back). This should fill your TV screen and not distort the image. If you still see the black bars, you will need to check your DVD menu settings for widescreen aspect, and supply more info on the DVD player and TV.
Nov 30, 2008 | Televison & Video
Now using an hdmi to dvi cable - screen size has reduced
Your digital box should have aspect settings as well. When watching HD TV and or movies there is a possibility to get the black bars on top and bottom. It all depends on the ratio it was filmed in.
Nov 18, 2008 | Philips Televison & Video
Philips 42PF7320A cropping issue
Pete,
When using a hd connection on a philips tv and (I am assuming this is the case) the tv disables the format features on the tv and only lets you select widescreen and automatic, if you are using hd adjust the picture size from the cable/satellite box, look for it in the box's menu system or on the remote, it is usually labeled, aspect ratio, zoom, format or something to that nature, hope I helped you
Aug 20, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
High Definition Channels leave bar on top and bottom
More then likely it has to do with the aspect ratio of what you're trying to watch. Most DVD's are in widescreen format (2.40 to 1) like you would see in a theater but an HD tv is a 16 by 9 format or 1.85 to 1. Look at the DVD case and see. Also some HD shows are in widescreen so you'll get the same thing. You're only option to fill the screen is get movies in 1.85 to 1 or use your zoom functions however these do tend to distort the picture.
Feb 17, 2008 | LG 50PX4DR 50 in. Plasma TV
I just bought a ilo tv model dtv2794b and playing vcr's is ok but when i try to play dvd's i get big black lines on the top and bottom of the screen like i am watching a wide screen movie, there is a...
Most if not all DVD's are 16 by 9 even in 4.3 mode you are going to have those bars on this TV. Some television have a zoom feature to get rid of that but not this one.
Jan 14, 2008 | Televison & Video
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
838 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
