Question about Epson Expression 1640XL Graphic Arts Flatbed Scanner
Scanner streaking My Epson 1640xl scanner is leaving numerous vertical lines the entire length of the scanner bed with each scan. please help, thankyou
  • 1 more comment
  • tfran Aug 11, 2008
    There are various semi-transparent colored lines appearing in each and every scan I run with the 1640xl scanner. I thought it might be a driver issue, but it appears not to be. Please help! I do not think we can afford a new scanner,
  • Anonymous Nov 06, 2008
    streaking horizontal lines in scan. Shows up on monitor
  • Anonymous Feb 07, 2009
    The streaks are always in the same spot....
    Problem Solver:
  • 14 Answers
Is this only when you print?
Posted on May 01, 2007
  • Ryan Santy
    Ryan Santy May 01, 2007
    The reason I ask is cause the ink cartridge may be low
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
Epson 1640XL scanner with trans adaptor
just use scan feture in high quilty mode when yuor doing 8x 11 instead of instant transfer alot these epsons have isses did u dl the latest driver from website for it also www.epson.com
Jan 10, 2008 | Epson Expression 1640XL Flatbed Scanner
I have the Epson GT2500 scanner. There is a black line down the middle of every page that I scan
There is a speck of dirt or some such on the ADF Scan glass not the flatbed iteself. As the paper travels over the glass the speck of dirt is being seen by the scanner making a "line" appear on the entire length of the scan.
Feb 16, 2011 | Epson GT-2500 Flatbed Scanner
Red and yellow streaks appear in scans, always in the same location. The scanner was cleaned but the repair person could not find any problem with the equipment. Yet the streaks persist. How do I resolve...
execute a calibration to correct the wrong color:
  1. place your photo on the scanner, with a distance of 0.25 inch from the edge of the glass
  2. open Epson scan and select Professionnal Mode
  3. select the document source
  4. select the image type
  5. uncheck thumbnail then click Prevew
  6. crop the area of the image
  7. Click zoom to fine tune the area you see the streaks
  8. select the resolution of 72 dpi
  9. scan your photo
if the problem still not solved, you need to change the scanner unit , there are many dead pixels.
Dec 09, 2010 | Epson Expression 1640XL Pro Flatbed...
Verticle color lines on scanner bed and printout in photo mode
Hardware failure, nothing much can be done, just replace the scanner.
Aug 27, 2009 | Epson Expression 1640XL Graphic Arts...
Our Epson Scanners do not work from Photoshop CS4
Try using a separate scanner utility to do yr scans - not ideal but sorted my problem. I use the EPSOM scan utility with a Perfection 2400 scanner.
Apr 17, 2009 | Epson Expression 1640XL Pro Flatbed...
Mustek Scan Express A3 USB Scanner
I've had a similar problem with the streaks, lines and color bleeds appearing in the scan. Try uninstalling the all software and drivers for the scanner and reinstall. Worked for me. Have had to do this a couple of times since I've owned the scanner... about three to four years now.
Jan 25, 2009 | Mustek A3 USB Flatbed Scanner
Pictures scanned with Canon 4200f show streaks
when scanning photos and especially magazines, don't go to low on the dpi (at least 300) and select DESCREEN as well as grain correction: HIGH
Dec 31, 2008 | Canon CanoScan 4200F Flatbed Scanner
Epson 1640SU scanner, red line in all previews and scans
Most likely it is a spec of dust on the scanning sensor.  I recommend cleaning with a soft cloth and isopropyl alcohol.  More info here -  http://www.willshak.com/scanner/
Apr 29, 2008 | Epson Expression 1640XL Pro Flatbed...
Error message on Epson 1640 XL scanner
try to fix the usb cable or just replace it and reinstall the drive software disk. bye.
Sep 28, 2007 | Epson Expression 1640XL Pro Flatbed...
Epson Expression 1640XL Graphic Arts Flatbed Scanner Logo
396 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
