Question about Vizio L32 32 in. LCD HDTV
Black screen says no signal
Has new tv out of box connected and worked for one (1) day and since then only shows black screen with no signal.
    Problem Solver:
  • 3 Answers
Check your inputs and verify that you have the components hooked up correctly or snug. try running a new scan in the tv mode
Posted on Dec 31, 2008
I'm not sure what card, I need to replace on my TV to fix it and was hoping you could help.
You are on the right track determining that there is a connection hassle preventing your tuner from working properly. Could be a bad wire connection or a bad solder joint on the board.
Feb 03, 2016 | Televison & Video
We have an NEC Plasma 60xp10 tv and NEC RU-M111 remote controller. we accidentally hit the pip button and now we can't get it to turn off. a black small box randomly pots on and off.
The black box is likely in the CC area labeled TEXT and can come from the set or a box connected for signal.
The other issue sounds like PIP or picture in picture is engaged.
Both issues may require the original remote to turn them off.
Dec 15, 2012 | NEC PlasmaSync 60XP10 60 in. TV
I have a Polaroid TLX-04240B It comes on and Displays the Polaroid logo, then it goes to a black screen with the HDMI1 input box on the top right hand corner. THis box eventually disappears, leaving me...
Buy another HDMI cable.Try another HDMI cable with another HDMI hub on the tv port.If u still have the same problems,mean the whole main tv Tuner signal board have problems and the caused.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
May 19, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
When I turn the tv on the screen lights up for a few seconds and then there's a clicking sound and the screen goes black
ours would do that i wont guarntee this will work but try using a different connection like we had a HDMI cord running to our cable box and one day it just went black so i unplugged the tv and still had the other componet wires hooked up to the box i thought it was the cable box so i tried another one and switched the input on my tv and it worked after a few days i could use the HDMI connection again not sure y but hopefully this is what your problem is.
Feb 16, 2011 | Element Electronics Televison & Video
I was using the satellite remote to find another show when the TV picture went black, then a minute or two later, the audio stopped. The satellite signal is still there (It is being received by another...
Hello.
First you have to figure out location of problem. That means is it inside of your new TV or outside of it?
Best way is to connect DVD player with new set of wires to different input and make sure it is working fine picture and sound wise. If OK - connect it to the same input that you are using with satellite box right now. If it works just fine - problem is outside of TV and originated in box or connection cable.
If DVD player does not work on any input - you have to call your TV manufacturer and schedule an appointment for repair tech. It is should be free of charge because you have 1-year warranty.
Or you can simply return/exchange your TV at the store you purchased it from (depend on store policy).
Regards.
Russ.
Dec 01, 2010 | Televison & Video
No signal onthe screen
If you are connected to a high definition cable box or satellite tv box you would not need to turn to channel 3 on your television. The television would need to be in the right input either component or hdmi. If someone connected the tv to the cable box or satellite tv box with a coax cable like an antenna cable then the tv channels will be available on channel 3 as well but they will not display in high definition. You change channels with the cable box/satellite tv box remote control. If the above is not correct and you are only connected to an antenna cable and not to a cable box or satellite tv box you will need to complete a channel search from the tv menu. It sounds like you are using a cable box/satellite tv box and that the tv is on the wrong input. If the cable box/satellite tv box is not working (i.e. just a black screen) on your television than that is a different matter entirely.
May 10, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
While watching tv on our new 42in.lcd flat screen and hooked up to our new hd cable box from comcast there are intermitent total signal losses from 3-5 seconds . Tv says searching for signal for a few...
yes we have to do a process of elimination to fix or narrow the problem down. try another box and see the results.if box work on another tv then u have tv problem
Aug 17, 2009 | Polaroid FLM-2632 Television
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Aug 05, 2007 | Vizio L32 32 in. LCD HDTV
SVA TV
If you had this problem from Day one, you should go directly who you bought it from and see what they can do for you for the company info or service agent.
Sep 26, 2006 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Vizio L32 32 in. LCD HDTV Logo
64 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
