Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
My printer is new and jus instal a new ink
I just put new ink and my print its blury its like the yellow is not mixing
    Scholar:
  • 82 Answers
You need to align the cartridges whenever you install the new cartridges and/or you install the printer.
Go to Start >> Printers and Faxes >> Select your printer
Right Click on the printer and click on Services Tab and
Press
"Align the Print cartridges"
Make sure the Printer is turned on
it will Print one Alignment Page
Choose the best aligned option and Select on your Computer Screen
I hope this will solve ur problem
Best Of Luck
Posted on Dec 30, 2008
  • xclancy
    xclancy Dec 30, 2008
    or
    1. Clean the printhead.
      1. Press Menu.
      2. Select Clean Printhead, then press OK.
      3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
      4. Wait for the On/Off light to glow a steady green.
    2. Engage the photo tray by pushing it in until it stops.
I change printing inks, but the yellow color does not print note, I've cleaned up several times but to no avail Please do reply with thanks
Ink printers mixed all the colors to print one color. If your hello isn't printing properly than it may be your other colors that need changing. When you open up your printer to change the inks remove you inks and there may be a latch of some sort depending on your model. Remove the print head that was held in place by the latch and clean with a cloth. If this doesn't work you may need to buy a new printer. Print heads are very expensive to replace and not worth the cost for a new printer
Feb 05, 2017 | The Office Equipment & Supplies
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Stripes in printing pictures in canon ip2700
Run the utility maintenance printer coming with the printer , for to clean the head from your printer.
God bless you
Jul 28, 2013 | Canon iP2700 Inkjet Photo Printer
Printer will not print yellow or orange, but prints other colors correctly. Brand new lexmark cartridge.
Yellow is one of the printer's "primary" colours.
Orange is mix of "red" and "yellow".
So, an empty "yellow" cartridge, or clogged ink-jets would cause your symptoms.
Sep 17, 2010 | Lexmark Z705 Photo Jetprinter InkJet
Ink Problems. is only printing with yellow ink
You may need to replace the Print Head or Purge Unit.
May 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
After replacing cartridge in dell 810 the colours printing wrong
Hi
If you haven´t used your inkjet printer for a while it may just be dry ink clogging some of the nozzles in the print head.
To check if yours is clogged...
Remove the ink cartridges
Holding the cartridge upright and press down gently onto a paper towel.
The colour cartridge
you should see YELLOW, MAGENTA (red) and CYAN (blue)
But if any colours are missing? The inks have probably just clogged up? and you will need to buy a new one or if you know you still have ink then you can easily unclog it with a
Magic Inkjet Flush Kit (Which you can find on Ebay)
MIXED COLOURS
If you have others colours coming out then the colours have mixed...
Sometimes caused when people put tape onto the inks to keep them moist but instead the colours mix through capilary action.
If so... leave print head sitting on a paper towel for a few mins until the correct colours appear.
Read more about ink clogs here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
To prevent an ink clog it is best if you print something regularly about every 10 days to keep the tiny print head nozzles / jets open. Otherwise the ink in the print head will thicken. Then it´s like trying to pass a camel through the eye of a needle.
So to preven inkjet ink from clogging print something every 10 days if you dont have anything to print, use something like these test prints
PRINT TEST SHEETS FOR USE WITHMagic Inkjet Flush
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Good Luck!
Hope this helps you!
Tinteiros (Ebay)
Oct 28, 2009 | Dell 810 All-In-One InkJet Printer
MY MF210C IS ASKING FOR YELLOW INK. I AM ONLY
Your printer mixes colors even with black, you must have ink in all carts.
Aug 01, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Serious Color Printer Issues
This is to do with the way in which the cyan, magenta, yellow and black ink is mixed to produce all the colours e.g. to print "red" requires both magenta and yellow ink. Thus, if the magenta ink is not flowing for some reason, for example, the "red" will print out as yellow. So, make sure all your cartridges and nozzles are working properly.
If you need further help with this, please post a new comment to this effect.
Oct 18, 2008 | Epson Stylus C62 InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
49 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
