Question about Kenmore Elite HE4 Electric Dryer
New dryer does not dry clothes, cleaned vent to no avail.
Gas dryer is new but doesn't dry clothes, i've cleaned the vent there doesn't appear to be anything stuck, my old dryer worked fine is there something else I can check?
  • Ron Buice
    Ron Buice May 11, 2010
    Open the front panel, turn the dryer on and tell me what it's doing.
    1. Do you see a flame?
    2. How long does the flame stay on?
  • 91 Answers
Make sure the vent is cleared ,sometimes all of cust / think they clean out but instead make clogg even worse,,, repl/coils remove 2 screews 1/4 in from botom panel heating coils are black in color simple fix,,,,,,,,
Posted on Jan 04, 2009
Samsung gas dryer will work but will not dry clothing
You have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, and recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance.
Oct 23, 2015 | Samsung Dryers
Gas dryer will heat but won't dry clothing
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, and recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance.
Oct 23, 2015 | Dryers
Gas shuts off early on dryer
most heating problems on dryers are caused by restricted airflow. your problem sounds similar. Follow the vent line all the way to the outside vent flapper and make sure that you have a STRONG airflow and no accumulation of lent, reducing the airflow. Verify the problem by disconnecting the vent hose and confirming that the dryer works OK when vent is disconnected.
Jan 31, 2015 | Whirlpool Dryers
I have a problem with Samsung dryer DV665JWXAC . the clothes do not dry properly unless i turn on the bass button. I have a new exhaust vent installed but no avail. Also the dryer takes over 3 hours t
Is it electric or gas? It it is electric, try re-setting the breaker for the dryer on the main house panel.
If its gas, make sure the right amount of gas is getting to the dryer.
Dec 03, 2012 | Dryers
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
My LG dlg2532 takes forever to dry clothes. When the drying cycle ends, the clothes are still quite damp. It's a gas dryer and the dryer seems to be getting gas since it does eventually dry the clothes...
How long are the vents? do they go for miles in your house?(sarcasm) Does the dryer have good ventilation? Check the vents again and make sure it is clear.
May 27, 2010 | LG DLG2532 Gas Dryer
New dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore Elite HE4 Electric Dryer Logo
82 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
