Question about Frigidaire FEQ1442ES Electric Dryer
Can't Put Belt On
Hi, I have a Frigidaire Model #GLER341AS2. My belt broke and I took off the little vent on the back to see the belt just laying there. Now the real problem is once I buy a new belt, how do I put the thing on? I can't figure out how to take anything off the put the belt around the drum. Help!
  • Anonymous Feb 17, 2009
    belt keeps coming off and heated air is heating up the room becuase it is exposed.
    Scholar:
  • 140 Answers
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Posted on Dec 30, 2008
Frigidaire model# GLER341AS2 humming noise
Hello friend, thanks for your inquiry!
I understand that your Frigidaire dryer, GLER341AS2, is making a humming noise. It could be a possible issue within your belt, motor, or the blower assembly. The manufacture provides to a dryer preventative maintenance kit part number 5304457724 and it costs $45.12 plus tax and shipping. I would also recommend contacting a professional to help avoid any unnecessary purchases. I hope this helps. -Matt
Aug 15, 2014 | Frigidaire Dryers
My frigidaire dryer model number gler341as2 is giving me a burning smell why is that?
Hi kmcgilvery...
That burning smell is probably a lint build up in the blower system of the dryer.
You will need to remove the back of the dryer and look for the vent tubing going to the hose connected to the outside. Once you find the tubing then disassemble and clean the tubing and blower wheel of dust...then clean your flexible vent tubing you have attached to the back of the dryer.
Please take time to rate me
Sep 05, 2011 | Frigidaire GLER341A Electric Dryer
Belt broke how do i chane this
Lay it down on its side, unscrew the cover over the brushes (don't lose them). You may have to pull the brushes out depending where the belt goes. Slip the belt on where it goes and put everything back together. The roller may be a little hard to put back in because of the new belt being tight but it will go on with a litte pushing. Good luck. Mine breaks all the time so I have it down to an art on mine. Just takes a few minutes.
Feb 19, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
I have a Kenmore Gas dryer model 11072702101 gets hot does not spin
Hi, Problem here is that your belt either came off or is broken. To get to it, remove two screws at vent. Take a putty knife and press in on the front left and right sides just under the lid. Lift up and prop. You'll find two more screws at the top of the front on either side. Remove. Front will fall out to you and lift up. Remove doorswitch wires noting where they came off of. NOTE FIRST, UNPLUG THE DRYER! Belt part number is 341241 at $20.38. To install, belt around drum, lay down with flashlite. Belt goes around motor shaft. Pull idler pulley back put belt over it and release. Reinstall cab. way you took it off. Hope this helps.
Jan 20, 2011 | Dryers
My Frigidaire dryer model GLER341AS2 will not turn on. Also the light in the dryer will not come on.. but I can turn the inside of the dryer with my hand.. Could it be a fuse or do I need a new belt
please check to see if any fuses are bad or breaker thrown.
if not have someone test the outlet for 220vac.
the belt could be bad but not likely. if the light is out too. change the bulb to see if it has just went bad.
Dec 15, 2010 | Dryers
Frigidaire Model # GLER341AS2 does not start. When turning the "ON" switch a buzzing sound happens, nothing else. I have unplugged, flipped the circuit and re-plugged in. Did not work. I have turned...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2010 | Frigidaire Dryers
When Turned on, drum will not spin?
if the motor is running,your belt is the problem.if all you hear is a slight humming noise,you may have a bad motor,or something caught in blower. if the drum turns easily by hand,its probably the belt
Mar 05, 2010 | Frigidaire GLER341A Electric Dryer
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEQ1442ES Electric Dryer Logo
259 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
