Question about GE JKP27 Electric Double Oven
Fault my top oven won't work. beeps a F 3 code
  • 3 more comments
  • steve clark
    steve clark May 04, 2007
    A new sensor fixed me right up!
    Thanks powerman!
  • steve clark
    This problem had been checked out by a "local yokel" which charged a expensive service fee. He said this was in our circuit board which was not available anymore. Fixya contact POWERMAN saved the day. Our church can now fix biscuits on both the bottom AND top ovens!
    Thanks Powerman!!
  • texhausted Nov 09, 2007
    I think someone messed with the self cleaning button on my 15 year old oven. [I had never used self-cleaning.] The bell started ringing and wouldn't stop. We had to shut down the oven at the panel. We did get a "F1" failure code = Failed Transistor in Control. The correction: If code cannot be cancelled, replace the ERC [Electronic Control (ERC-II).
    GE no longer makes the ERC replacement part #WB27K5040 - the electronic control - but it is available on internet.
    Question: Can just the timing bell be disconnected, or do I need to order the complete control panel and have a service tech install it?
  • mooselois Mar 08, 2008
    Have the same 1992 GE double Wall Oven model #JKP27WCF1WG with electronic sensor control issue. Top oven does not work. Called Sear Repair, paid $65 for service call to learn that part was not available. Sears would take $65 off in combination with any in store sale. We tried Sears today. They blew us off. Store manager went home early. In frustration tried national Sears cutomer service, same result. Shall purchase tools for business from someone else. In my opinion, shopping at Sears is a stupid decision. What suggestions do you have for repair on our 24" double wall unit?
  • richang50 Feb 07, 2009
    During oven operation the display will indicate a F3 error and will beep until it is cleared. This may take 20 minutes to occur. Is the oven sensor bad?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
F3 usually means an open oven sensor. Turn off the power. Disconnect the sensor harness from the control. Measure the resistance with an ohmmeter. The resistance should be approximately 1080 ohms at room temperature. If it is greater than 2900 ohms it needs to be replaced. Make certain you disconnect the power before messing with the controls. Look for damaged harness terminals if the sensor checks out to be OK. There should be a set of service instructions in the top of the oven that will help you identify the specific connections for the sensor.
Posted on May 01, 2007
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven just beeps when i turn it on
Hit stop clear then reprogram oven If that won't work unplug for a short time plug back in and see if this works. It found a fault code in the oven control and if you can't reset it. You will have to order a new one. Go to managemylife.com if you need to download manual
Dec 09, 2011 | Kenmore Ovens
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
Frigidaire won't stop beeping f1 style
HI, this is a electronic oven control board failure code.
Replace this damaged electronic oven control (also called EOC or clock). It has failed.
Aug 13, 2009 | Frigidaire FEB27S5A Electric Single Oven
F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Nov 09, 2008 | Thermador SC272T Electric Double Oven
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
428 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
