My monitor is not working - Computers & Internet
  • 2 more comments
  • Anonymous Apr 06, 2009
    monitor is nor working what problem what happen what i do explain
  • Ed Deguzman
    Ed Deguzman May 11, 2010
    What type of monitor do you have and do you have a digital or analog connector ?
  • Brett McGuigan
    Brett McGuigan May 11, 2010
    ok i need some more detail, will the monitor turn on?.....?? could you explain exactly what is happening.....
  • Aaron Daub May 11, 2010
    Details.
    Problem Solver:
  • 7 Answers
First, stop to realize that some monitors are powered through the cable that comes from the computer stand alone unit. Some get power and have a normal electrical receptacle in the rear of the monitor. Some monitors have a little hole for the installation of a small plug from a step down transformer. Kind of like the one use in cell phones. If you have any lights on the monitor....then it isn't the power. If you do, then replace the cable from the stand alone to the monitor. Or, if you have another monitor, try it with your stand alone. But, most trying to help you are RIGHT. Details, you might wish to give more detail to get an accurate effort from this support page. Good luck.
Posted on Dec 30, 2008
Viewsonic monitor vs10047
hi,
try plugging that monitor into another computer to diagnose wether your computer malfunctioned or it is indeed the monitor. if you plug THAT monitor into another working computer and it works then your computer is bad, if the monitor doesent work on the new computer then the monitor is bad...
Sep 25, 2013 | Computers & Internet
PC SWITCHS ON BUT NO PICTURE
1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.If the new monitor you connected does not show anything either, proceed to Step 6.If the new monitor you connected does show information from your computer, proceed to Step 7.Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.Chances are your original monitor is working fine.Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8 Replace the monitor.
Sep 27, 2011 | Mesh Matrix 6000+ DX PC Desktop
My monitor worked yesterday but not today the vga lead works in a different computer
Monitor 1 does not work in computer 1.
Monitor 1 does work in computer 2.
Try Monitor 2 in computer 2 -- it should work.
Try Monitor 2 in computer 1 -- if it does not work, then computer 1 has a "dead" video-card.
Apr 11, 2011 | Computers & Internet
My pc does not give display ? Why
Time Required: Testing a monitor could take from a few minutes to much longer depending on the cause of the problem Here's How:
  2. Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable. Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.
  3. Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.
  4. Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.
  5. Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.
    • If the new monitor you connected does not show anything either, proceed to Step 6.
    • If the new monitor you connected does show information from your computer, proceed to Step 7.
  6. Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.
  7. Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.
    Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8.
  8. Replace the monitor.
    WARNING: A computer monitor is not a user serviceable device. In other words - do not open the monitor and attempt to repair it yourself. If you would rather have your dead monitor serviced instead of replaced then please let a professional do it.
Aug 02, 2010 | Dell Dimension 2400 PC Desktop
Check signal cable
Check if the monitor is not working by connecting this monitor to another computer.
If the monitor woks on another pc, then the pc is the issue and not the monitor.
If monitor doesnt work on the other pc, then it's the monitor that needs replacing.
I hope this helps you :)
Jul 13, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
Will my monitor work with the new windows 7 operating system?
Yes your monitor will work with windows 7 it has a generic driver for monitors installed into the system.
If your monitor has a driver cd for it, for more cababilities found on the monitor you may have to visit there web site for updates. Other than that your monitor should work fine with no problems.
Mar 23, 2010 | AOpen F2705 17" LCD Monitor
Hey my monitor turns on but than turns black after a few seconds? What can be wrong with it?
Most monitors turn blank after a few seconds if they are not receiving a signal from the computer. Check the graphics cables and try another monitor if you have one. If neither works, then you have a graphics card problem.
Dec 28, 2009 | HP f2105 Monitor
Monitor comes on and displays for a second then goes blank.
New monitor? Does old monitor still work? Did the monitor ever work? did the computer ever work? is power light on computer on? is power light on monitor still on?
Oct 15, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
