Question about Maytag MSD2456G Side by Side Refrigerator
Ice Maker stopped making ice - water dispenser is fine.
Hi there, I have a Maytag MFD2561HES French Door Refrigerator, with bottom freezer that I purchased about 3 years ago.
The Ice Maker (model # 12685007) all of sudden quit working a few days ago. I am still able to get chilled water out of the water dispenser on the left side wall of the refrigerator.
The freezer temp is set at -1 degrees Faherenheit. It has always been set at that temp since we got the refrigerator. I don't see any leaks in the freezer or on the outside of the fridge. I have not pulled the refrigerator to look at the back but no water leak is evident around or in front of it. What could possibly be wrong? We don't use a lot of ice so I would imagine the lever had been in the up position a lot of the time since we bought this unit. Could that have frozen the line into the ice maker because of the lack of water circulation? Would defrosting the unit solve anything?
If the problem was due to the inlet valve, wouldn't I quit getting chilled water thru the water dispenser? What about a leak? How urgently should I fix my issue or can I continue to do nothing eventhough the ice maker seems to have quit working? Or am I totally out to lunch? Please help me troubleshoot this issue.
I have had the same problem with different problems each time. The first time the stop lever came loose on one end. This resulted in the ice maker remaining in the off position but looked like iWhen I removed that it worked again. Hope this helps
Posted on Apr 22, 2009
  • 115 Answers
Well first the icemaker valve and water despensor valve a separate so you might want to try but to change it out you have to change both valves cause they made together then also check and makes sure your tube is not froze up and if that aint it then change your icemaker now for a little tip the icemaker will not run as long as the freezer door is open
Posted on Dec 30, 2008
  • Steven Carter Dec 30, 2008
    well first the icemaker valve and water despensor valve a separate so you might want to try but to change it out you have to change both valves cause they made together then also check and makes sure your tube is not froze up and if that aint it then change your icemaker now for a little tip the icemaker will not run as long as the freezer door is open
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker does not make ice
Is the freezer freezing the contents good?
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Our ice maker stopped working. there is water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hfdjdfh
May 29, 2010 | Maytag MFD2560HES Bottom Freezer French...
MFD2561HES not dispensing ice
removed freezer door and drawer by lifting and pulling out. removed ice maker with 3 screws and disconnect electrical plug. applied heat with hair dryer to water line. and all is well
Nov 15, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFD2561HES not dispensing water or making ice?
Hi. is your Maytag on the recall list? Do a google search. You may by one of the 1.6 million owners affected. If this solution has assisted you, please rate it. ricardok45
Mar 13, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MSD2456G Side by Side Refrigerator Logo
1,365 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
