Question about Compaq ProLiant 3000 Server
OS Loaded on SCSI HDD Cashed
I have a Compaq Proliant 3000 Server with three 9.1GB SCSI HDD. The HDD0 had OS Win Server 2003 Standard Edition. While booting the server the only two SCSI HDD 1 &2 got identified.
can anybody help me fix the problem and would I be able to restore the HDD
  • martinmarty May 11, 2010
    It sounds like RAID was not in use, otherwise the machine could potentially have booted up in spite of the failed drive. Can you confirm?
    When booting up, do you get an optoin to press a key sequence to enter a disk utility? This is the first place I would look to see the status of the drives and perhaps if the system was configured for RAID or not. If the system was configured for RAID, you might have some hope of getting it up on just the remaining drives.
    Sorry I'm not expert on this but since there are no other replies I'm just trying to give you some ideas.
    See what you can find in the disk configuration utility and let us know.
    Sergeant:
    Champion:
  • 208 Answers
If the Bios did not detect the third drive, try switching it to a known working slot and see if you have a bad drive, or something wrong with the cage or cabling. The 3000 were shipped with either a 68 pin drive cage or a 80 pin drive cage. The 68 pin drives and the 80 pin drives are not interchangeable. To make matter worse, the drive cage would be configured as simplex or duplex. For duplex mode, you will need to connect two SCSI cables to the cage.
Posted on Sep 03, 2009
My server cant boot after a fresh intall
Reshuffling disks will disturb the Logical drive .Recreate RAID Install OS , Set the Boot controller order in system bios Pressing F10key
Jul 25, 2012 | HP Compaq ProLiant ML350 G3 Server
How to install scsi driver for hp prolaint ml 350 server and then install server 2003,because my os 2003 is currpted.
windows server 2003 enterprise edition with SP1 or SP2 , can detect
SCSI driver automatically.
Apr 22, 2011 | HP Compaq ProLiant ML350 G3 Server
Sir, we have HP prolient windows 2003 server (standard edition ) SP2 we are using both LAN/WAN connection in some of the clients using dual IP address. All the client machines are running smoothly but...
hung.
it's virus infected.
OS corruption..
or has hardware issues (had disk going bad?)
why not get it serviced, by a tech.?
reload the OS? if it can't reload the HDD is bad or PSU .
May 16, 2017 | HP Compaq ProLiant ML370 G3 Server
We are using IBM X226 server with 4 GB RAM & 146 GB SCSI HDD. We are using it for ERP application . It is very slow . When HP proliant ML 110 server with 2 GB & 160 GB SATA is used in its place it...
strange. with 4gb of ram, it should be fast. try to install better version of windows like win 7. it could help you. just don't install vwindows vista cause is slow as hell. let me know if it worked
Jun 28, 2010 | IBM xSeries 226 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Compaq ProLiant 3000 Server Logo
195 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
