Question about LG LS-L1210CL Mini Split Air Conditioner
Unit constantly makes a clicking noise.
I have a LG artcool air conditioner in my bedroom. The unit constantly makes loud clicking noises that keeps us awake. The noises are not always the same volume, and not in any pattern. Driving me crazy.
  • 4 more comments
  • thompsonkj Dec 30, 2008
    Thanks for the prompt response. I think it does. The air-con is an LG artcool.
  • johnsamuel37 Feb 12, 2009
    I have 2 Mitsu Heavy Industries, one in the living room and one in the bedroom. The one in the living room is perfectly alright. However, the one in the bedroom keeps clicking 15 times every 10 minutes, so it is impossibe to sleep. But there is a pattern to this madness. While cooling at 20 degrees it is quiet, while heating at 30degrees it is quiet. It is just in between temperatures. The mechanic from Mitsu, said that a) if I keep the bedroom door close, it will make sound. b) the wall unit inside was not level but very slightly slanted (sloppy installer) c) yes, it was the heating rod that caused the clicking. I wish some mechanic would open the wall unit so that I could see what is making the sound. I wish they would tell you this when you purchase the equipment.
  • AmbrishSheth May 15, 2009
    15 May 2009
    I have a Voltas Vertis Gold 2 ton AC installed in the living room. It hardly makes much noise when the ambient/room temperature is really high. However, when the room temperature starts nearing the upper end of the temperature range that can be set ( 17 - 30 degrees Centigrade) i.e. whe it is around 31-32 degrees Centigrade and you switch on the AC, it makes all sorts of clicking, ticking noises of varied volumes. The noises emanate sometimes several times a minute and are very disturbing.
    Somebody told me that the noises are the cracking noises of discharging capacitors which are sub-standard in quality. So I got the best capacitors available and replaced them on the PCB. Sorry to say, but it idin't help. I tried removing all the screws on the different plastic parts and panels so as to allow for some movement between them while expanding and contracting but that didn't help too. Even completely removing the front cover did not help, nor inserting rubber washers beneath all the screws.
    Needless to say, I'm still trying.
    If any of you have a solution or an idea, do let me know.
    If I find a solution, I'll do the same.
    Ambrish
  • David Robinson May 11, 2010
    Does this unit have the electronic filter on it?
  • kamsakmndsvkljnfv
    kamsakmndsvkljnfv Mar 09, 2014
    JOSHMEUL37 can you please email me? I'm having same exact problem with the unit and it's driving me crazy and you're the only person on the whole internet who's having same issues so I need to talk to you. kmia305@icloud.com
  • Anonymous Mar 31, 2014
    when air conditioner is on the inside unit makes a wind type noise blowing out
    Scholar:
  • 140 Answers
Electronic filters use static dicharges to filter the air. Unfortunately the make that clicking noise when they discharge. LG calls it a plasma filter. Clean both the regular and the plasma filter to see if that helps.
Posted on Dec 30, 2008
  • 1 more comment
  • David Robinson Dec 30, 2008
    Also LG says that the front panels make a cracking sound due to expansion and contraction from temperature changes. Sorry, your stuck with that sound. Anything else just ask. Please remember to rate me so I know if I'm helping. Thanks.
  • AmbrishSheth Jun 04, 2011
    4 June 2011
    Dear dmr0dmr,
    Sorry for the delay in posting this reply.
    After reading your suggestion, I removed the ion filters from my AC. That helped significantly to reduce the the clicking / ticking noises. Thank you very much.
    However, after a couple of hours of operation, light ticking noises do arise. Would you please guide about what might be the reason & suggest a solution.
    Thanking you, once again, in anticipation
    Ambrish
  • David Robinson Jun 06, 2011
    Light ticking noises could be just normal expansion / contraction noises from the evaporative coils. Unfortunately with this type of design where the coils are in the room with you as opposed to a central air conditioning system where the coils are farther away and separated by duct work, you will hear all of the changes in the metal and surrounding plastic. As far as a solution, I don't believe you can eleminate the ticking noises without changing the physical properties of the materials used to construct your A/C system. This is a diplomatic way of saying , "that's just the way it is". If it is light tcking then everything is working fine and you should embrace the sound as a verification of operation. If the ticking gets louder or consistant in frequency and volume then you may have a problem with your fan.
    I wish I could travel to your location to witness exactly what you are experiencing so I could give you a definitive explanation.
    If you want to contact me directly and email me pictures, videos or any other way of helping me know exactly what you are experiencing then send them to davidr@westernaircontrol.com.
    I would be very happy to help you in any way that I can.
Sharp comfort touch air conditioner screen doesnt show settings and buttons wont work after cleaning. help its hot!!!!!
Switch off the unit at the isolator or fuse box. Leave off for 10 mins to reset. When powering up again and it still wont work, check your remote control batteries are good. Also confirm you haven't "blanked out" the display. Some controls have a display or LED function which blanks out the display so that the lights are not bright at night time. (For bedrooms so that the light doesn't keep you awake) Also check that you have not pressed a "child lockout button" This will stop anything ..
Jul 25, 2013 | Heating & Cooling
What does CH 24 mean on ArtCool mini-split?
Ch24 means your unit has a low or high pressure fault,check gas charge and if filters are clean see if helps
Aug 31, 2011 | LG Art Cool LA121CNP wall/window Air...
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
Our unit is making loud clicking noise and spraying water when in the cooling air condition mode, but not when the fan is on. What could be the problem, and is it fixable?
you may hear water splashing that is because it is coming off of the condenser the part that is outside the water runs off the condenser and is forced out by the fan for as the noise could be something in or on the inside fan blade or outside fan blade as long as the water is not coming inside your house and you have enough slope on the unit you should be ok
Jul 04, 2011 | LG Electronic Window Air Conditioner
C1 error on lg 18 artcool
C-1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace
Dec 11, 2010 | LG Heating & Cooling
LG Artcool Error Code C1. What does this mean? (Background info A/C unit works fine, cools as normal. Installed 2 years ago)
Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Nov 08, 2010 | LG LA185HV Split System Air Conditioner
My Artcool a/c internal unit began dripping alot of water after being used for 4 hours.... any ideas?
rochelle2511
I have an LG artcool unit too, with the same water problem. Have you found a solution?
Brad
b.emberton@comcast.net
Feb 12, 2010 | LG Heating & Cooling
Roof air unit too loud inside; quiet outside.
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
4,968 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
